Injector holes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 9 Lives, this thread has received 5 replies and been viewed 3194 times.
post #1 of 6 (permalink) Old 05-01-2009, 02:19 AM Thread Starter
Injector holes
What size are 24V injectors from the factory/stock
I've seen aftermarket in 6,7 & 10 hole options.
I was just curious as to what stock ones actually are? 6 hole?
Also are the ones with more holes a stock tip from another application? or are they custom made by bosch?
9 Lives is offline
post #2 of 6 (permalink) Old 05-01-2009, 03:16 AM
Stock is a 7 hole. I'm not sure of the hone size. As for other injectors, some are custom made by various different companies, and some are other tips that have been modified. The schied 6x.012 are I believe a modified tip from a mack application. But many companies use a stock blank and EDM a new hole pattern into them. 8 holes are also common. There are other factors that play into the injector function as well, pintle lift, internal fuel gallery modifications etc... I'm really not too up on those though, so I can't tell you what the differences are.
post #3 of 6 (permalink) Old 05-01-2009, 03:25 AM Thread Starter
Thanks for the info. That was about all I needed to know....
I had no clue if some AG apps used a 8 or 10 hole injector and thats how they came up with those.
Also curious as to what process some of these big companies use for their tips?
I know Industrial injection used to at one time have their injector tips EDM
DDP from what I know is extrude hone ?
Has II gone to extrude honed tips?
9 Lives is offline
post #4 of 6 (permalink) Old 05-02-2009, 01:14 AM
Of Course
90% of companies are getting there nozzles from the same source, DDP is Extrude Hone and II is EDM. The 8-hole nozzles are cheap knock-offs, often known as the Jammer nozzle, quality isn't the greatest. Many people will alter hole count and size via EDM and Extrude Hone, the biggest variable is the way they are assembled. Agricultural nozzles use a differnt design, Sac style vs VCO(valve covered orifice). I think this is one area where people should be asking more questions, and getting better answers, after all, it's your money.
That Guy is offline
post #5 of 6 (permalink) Old 05-02-2009, 06:00 PM Thread Starter
Now there is a guy I bumped into on ebay that is selling 5 hole 24V injectors. They are from what he says stock. I was buying up a bunch of 12 & 24 injector cores to send off to be edm modified and noticed when taking the injector bodies apart that I couldn't tell much difference from a 12 to a 24V tip. Im guessing the physical tip its self is the same but the spray angle is different?
9 Lives is offline
post #6 of 6 (permalink) Old 05-02-2009, 11:02 PM
Of Course
No 24v nozzles are 5-hole.
That Guy is offline
20" rockstars cracked or pin holes? 99cummins3500 General Parts and Accessories 11 04-03-2009 04:07 PM
ditching the badges, and finding... Holes??? Sleeperstroke 1994-2003 7.3L Power Stroke 3 03-23-2009 02:40 AM
2 dead holes across from each other. Navy_Seabee_CM 7.3L and 6.9 IDI (Pre 1994) 5 04-05-2008 04:39 PM
Injector Holes Dual K20s 5.9L Cummins 12 Valve (1994-1998.5) 11 04-04-2008 01:56 AM
Which Badges don't have guide holes 07'? I10HaulR General Dodge Discussion 6 09-17-2007 02:45 AM
