Low fuel pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by phillyboy, this thread has received 20 replies and been viewed 2551 times.
post #1 of 21 (permalink) Old 05-01-2009, 02:21 AM Thread Starter
Low fuel pressure
Hi we got a 2001 dodge cummins running 100hp injectors and a edge juice with attitude, it's got a new injection pump and the lift pump is only 10 months old. The lift pump was bought at carquest and was a upgraded one, the problem is we can't run any higher then level 3 because of low rail pressure, on level 4 it's down to 4 psi wide open. The edge is showing 18 psi idling but seems to higher than usual. thanks
phillyboy is offline
post #2 of 21 (permalink) Old 05-01-2009, 12:32 PM
cowboytw13's Avatar
running that big of injectors and an edge, you need a large lift pump. I would recommend the Airdog 150 or FASS 150
cowboytw13 is offline
post #3 of 21 (permalink) Old 05-01-2009, 01:39 PM Thread Starter
Thanks, was going for the fuel system next but maybe should of done it first, is 18-19 psi a little high for idle?
post #4 of 21 (permalink) Old 05-01-2009, 02:00 PM
It's a little high. My Raptor pump pressure at an idle is 15-16. At WOT it only drops to 13-15psi. I have Sticks and a monster comp file on level 10 and have no fueling problems any more. With my stock Carter it would defuel due to lower pressure after 5-7 sec of WOT.
03 Power Smoke is offline
post #5 of 21 (permalink) Old 05-02-2009, 02:13 PM
2nd Gen Guru
Mopar1973Man's Avatar
Agreed! you need a big pump for big sticks...
Mopar1973Man is offline
post #6 of 21 (permalink) Old 05-03-2009, 02:00 AM Thread Starter
Thanks for the help, Was also wondering if we could get by with one of those holly blue or black pumps for a while, kind of straped for cash since I just upgraded the transmission.
post #7 of 21 (permalink) Old 05-04-2009, 01:25 AM Thread Starter
Anybody think i could get by with one of these pumps for a month or two. Thanks
post #8 of 21 (permalink) Old 05-04-2009, 01:35 AM
TDG Mafia
Jeffybuilt's Avatar
Although I know they are not the best... I have been running a Holly Black 150 for a year and a half now with no problems. I dont have injectors, so I really dont fuel to heavily. The problem with these pumps is there is a lot of demand placed on them, and there is usually a decent sized pressure drop associated with them. For example, right now, I have mine set at 18.5 at idle, and under WOT it can drop to 14.5. I have been told the quality pumps (FASS/AirDog) will keep constant proper pressure under all throttling conditions.
To answer your question though, for a few months, you would be A-OK to run one of those pumps.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #9 of 21 (permalink) Old 05-04-2009, 06:31 AM
I think it will last a little while but they can die in less than a month too. I went through 3 in a year and a half. the last 2 I ran a fuel filter before and they still didn't last. Best to save the cash if you can and drive your truck easy and not waste the 120 on a holley
01quadcab is offline
post #10 of 21 (permalink) Old 05-05-2009, 12:38 AM
2nd Gen Guru
Funny...
I ran 5 carter campaign pumps in less than 2 years... At nearly $120 to $150 a pop... I sure wish I got off my rear end and got a AirDog sooner.
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Mods: X-over vs full fuel kit and pressure... bakantor 2003-2007 6.0L Power Stroke 39 03-10-2007 02:06 PM
$100 Off DJ's FUEL+ - Fuel Pressure Intensifier MOMBENZ Supporting Vendors Forum 3 12-13-2006 01:49 AM
anyone doing fuel pressure or oil pressure skinz0021 General Dodge Discussion 7 08-19-2006 02:42 PM
