'02 Cummins Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6.0turbodiesel03, this thread has received 9 replies and been viewed 1636 times.
post #1 of 10 (permalink) Old 05-04-2009, 08:10 PM Thread Starter
You can call me French
6.0turbodiesel03's Avatar
I have a buddy with an '02 cummins and he is looking for a box for his truck. I found an Edge Drag box in the dodge parts section and was wondering if anybody was running this box, or a comp box, stacked with a smarty. I don't know much about the electronics on the 24V, so please be patient with me.
-French
2003 Ford F-250
6.0L Powerstroke Diesel, CC, SB, 4x4
ZOODAD mod
DIESELS FOR CHRIST
6.0turbodiesel03 is offline
post #2 of 10 (permalink) Old 05-04-2009, 08:16 PM
The comp for sale would be an excellent choice. However, an aftermarket lift pump and gauges are needed.
#23 B.O.M.B. Squad[/B]
rwhite is offline
post #3 of 10 (permalink) Old 05-04-2009, 08:22 PM Thread Starter
He already has an Airdog 150 on his truck and gauges are on there way, so he is covered on that part of it. How would running this box on his truck with thestock trubo do. I assume really smokey and high EGT's.
-French
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #4 of 10 (permalink) Old 05-04-2009, 09:32 PM
cowboytw13's Avatar
Actually the EGT's aren't too bad as long as you aren't WOT all the time. I pull most big hills @ about 900 deg. pre-turbo. Not too smokey with the stock injectors, really only in between shifts is when i notice much smoke.
Unless you try to make it smoke!
cowboytw13 is offline
post #5 of 10 (permalink) Old 05-04-2009, 10:43 PM
Local Cummins nut
MOPAR MAN's Avatar
Send a message via AIM to MOPAR MAN
I agree 100% Edge makes great power & inproves milage also (as long as you can keep your food out of it) But like he said you will need gauges & a good lift pump like a FASS or AirDog. Also if its an auto start thinking about some upgrades like a valve body & TQ converter. If its a standerd trans start thinking about a clutch.
00 Ram 2500 4x4 5-spd, Balanced & blueprinted, O-ringed & studded CR Head W/head work, Billet Hamilton HD Big Stick Cam pushrods & Valve springs, Coated pistons & barings, all ARP studs & bolts, S&B CAI & AF1 Intake horn, Equal tube length header, 5" Turbo back Exhaust, Edge Juce W/Attitude (HOT), 120 HP EDM'd Injectors, Custom Garrett GT3788R BB Turbo, FASS 150/150, ValAir DD W/3600Lb PP, FluidAmper, Amsoil Bypass, 7" lift, HID's, Cowl Hood, 38.50x14.50x17,
Singles Club Member #244 Riding HIGH Club Member #43
MOPAR MAN is offline
post #6 of 10 (permalink) Old 05-05-2009, 12:35 AM
2nd Gen Guru
Mopar1973Man's Avatar
-French
Edge Comp / Edge Drag is a excellent box. I've got the Edge Com pand it does wonders for a mild fueling bomb to the truck. It improved my MPG's and the passing power is unreal.
As for stacking with a Smarty you will need to update your tranny (manual/auto both). If you don't it will slip for sure.
Mopar1973Man is offline
post #7 of 10 (permalink) Old 05-05-2009, 05:12 PM Thread Starter
Already working on the tranny part. He is already slipping a little bit and is having the tranny completly gone through, so he thought he would just finish it off I don't know how good of an idea that is, but oh well, not my truck.
-French
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #8 of 10 (permalink) Old 05-05-2009, 05:14 PM
2nd Gen Guru
Best off fixing the problem now that letting it grow to a really big problem...
post #9 of 10 (permalink) Old 05-06-2009, 07:12 PM Thread Starter
Well he got the used Edge Comp Drag Box off of an '01. Will the box plug right in or will we have to get a new MAP sesor plug. I have heard that you do and that you don't. I'm
-French
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #10 of 10 (permalink) Old 05-06-2009, 07:27 PM
Official TDG Doctor
hccumminssmoke's Avatar
-French
Gotta get an adapter from Edge...01 and 02 have a different Map Sensor, something w/ Oil Pressure maybe idk for sure. He will like the Comp/Smarty stack thats what I run...its good and it'll make some smoke if he wants too, but on 8 and 5x5 I can go smoke free normal acceleration oooorrrrr make traffic stop
Nate
hccumminssmoke is offline
06 cummins question breck84 5.9L Cummins (2003-2007.5) 5 04-17-2009 01:30 AM
cummins ISB question okiebindernut Medium and Heavy Duty 5 03-29-2009 02:16 AM
New to the Cummins have a question Powerstroke1 5.9L Cummins (2003-2007.5) 1 06-30-2007 04:14 PM
91 cummins question.... ramthisny 5.9L Cummins (Pre 1994) 9 01-24-2007 12:55 AM
Cummins question Slaughterhouse 6.7L Cummins (2007.5-2011) 21 09-03-2006 07:46 PM
