tranny issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firedog1310, this thread has received 8 replies and been viewed 1014 times.
post #1 of 9 (permalink) Old 05-10-2009, 04:10 AM Thread Starter
tranny issue
just purchased a 99 3500 w/autoa few weeks ago, today i was pulling a light load and noticed when i hit a hill it felt like it was jumping in and out of overdrive i cut overdrive off and it quit, later i rode to town and on the way back with parts for another vehicle i noticed from take off it didn't want to shift out of first until i let off the throttle but shifted fine after that. i work on vehicles but not a tranny man. any info is appreciated
firedog1310 is offline
post #2 of 9 (permalink) Old 05-10-2009, 05:28 AM
Throttle position sensor?????
1999 Dodge 3500 Dually, Cummins, Edge Juice with Attitude, BHAF, open exhaust, Auto tranny, 21 MPG and it pulls a giant camper pretty well at 11 MPG. Just added the Raptor 150 Pump and big line kit.
chevy is offline
The Following User Says Thank You to chevy For this addition to TDG:
firedog1310 (05-11-2009)
post #3 of 9 (permalink) Old 05-11-2009, 10:43 PM
That not shifting out of first is likely the TV cable being out of adjustment. As for the in and out of O/D, they have a tendency to do that. If I'm running unloaded, I keep O/D off until 55mph. Loaded, it depends on what I'm towing and the terrain.
The Following User Says Thank You to sstockton For this addition to TDG:
post #4 of 9 (permalink) Old 05-12-2009, 03:28 AM
TDG Mafia
Jeffybuilt's Avatar
Not to scare you or anything, but that is how my tranny failure started. It would stay in first (sometimes second) until I would ease off the throttle, than it would shift hard and be OK. It was like that for about 2 or 3 weeks, than was continuously getting stuck in 1st or 2nd, and sometimes would shift, and sometimes not. Needless to say, I got it rebuilt and built right, so no more problems... I hope for your sake it is an adjustment issue. Good luck,and let us know what you find out.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #5 of 9 (permalink) Old 05-12-2009, 02:19 PM Thread Starter
tranny issue
Thanks Jeff that was the first thing that went through my mind when it did it, since dodge trannys have had some problems in the past. I got in it the next morning it it has shifted fine since but i am still doubtful.
post #6 of 9 (permalink) Old 05-12-2009, 02:23 PM Thread Starter
adjusting tv cable
what is the procedure for adjusting the cable
post #7 of 9 (permalink) Old 06-17-2009, 07:18 PM
. I'm having the same trouble. . Torque convertor lockup kicks in and out on very slight excelleration at around 45 to 50 mph. . This question comes up all the time. . Hard to believe no one really knows how to correct it. . Some people say it is the transducer solenoid in the transmission. . Not expensive, a little messy to replace. . But did not make any differance on mine. . I was then told that the trottle postion switch (T.P.S.) would cause it. . Very expensive part but fairly easy to replace. . Again did not make a bit of difference on mine. .
. . Let me know if you find the answer. .
hdcolo is offline
post #8 of 9 (permalink) Old 06-17-2009, 08:17 PM
2nd Gen Guru
Mopar1973Man's Avatar
There is a TSB flash for that TC problem...
Then the alternator is the other cause. The diode pack will lose one diode and create a sinewave noise in the DC power causing weird problems also. So its best to verify the laternator by having it tested.
Bad battery cables or loose connections can do it too.
Mopar1973Man is offline
post #9 of 9 (permalink) Old 06-19-2009, 04:26 PM
Could be the TC lockup solenoid as well, however, you don't often hear of them failing. Do you run with O/D turned off?
Tranny issue fastfords 2008-2010 6.4L Power Stroke 20 04-30-2009 09:50 PM
tranny issue? Lurkin GM Transmissions 3 02-20-2008 12:29 PM
Tranny Issue?? redneckcummins 5.9L Cummins 12 Valve (1994-1998.5) 2 02-07-2007 10:35 AM
My 05 Tranny issue Dieselwrencher 2003-2007 6.0L Power Stroke 4 10-26-2006 07:33 PM
tune issue or tranny issue? licketysplit 2003-2007 6.0L Power Stroke 10 02-14-2006 10:58 AM
