3" factory exhaust w/ resonator vs straight pipe? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hotrodx199, this thread has received 10 replies and been viewed 4908 times.
post #1 of 11 (permalink) Old 05-15-2009, 11:15 PM Thread Starter
Hey, how much louder would the exhaust be if we removed the factory resonator? Dad left the resonator on the exhaust and to tell you the truth you really can't hear much unless you stuck your head out the window... Running a 3" straight pipe that loud? Does it get annoying on the freeway? I need answers. Thanks.
Hotrodx199 is offline
post #2 of 11 (permalink) Old 05-15-2009, 11:29 PM
bmoeller's Avatar
It's a lot louder than stacks, that is for sure.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 11 (permalink) Old 05-16-2009, 01:09 AM Thread Starter
wow really? is it because it would only be a single exhaust where it would give it the extra "pop"?
post #4 of 11 (permalink) Old 05-16-2009, 02:10 AM
I have 3" straight with a 5 inch tip. The 5" tip really mellowed it out. On the freeway its not annoying unless you are in the back seat. I love it!
smokeshow1 is offline
post #5 of 11 (permalink) Old 05-16-2009, 05:08 AM
bmoeller's Avatar
I think the change in the tone has the most to do with it. Also depends if you have a reg or quad cab, too.
bmoeller is offline
post #6 of 11 (permalink) Old 05-16-2009, 12:12 PM
2nd Gen Guru
Mopar1973Man's Avatar
Really... Here is straight piped 3"
WOT in the cab...
Mopar1973Man is offline
post #7 of 11 (permalink) Old 05-16-2009, 03:09 PM
I have 4in, with a muffler on that I want to get rid of, and a buddy of mine just straight piped his stock exhaust and his is much louder than mine. Makes me want to cut the muffler off real bad.
Carbur8tr is offline
post #8 of 11 (permalink) Old 05-17-2009, 02:00 PM
bmoeller's Avatar
YouTube - Broadcast Yourself.
WOT in the cab...
Ya, it is to me. It is the difference in tone.
I ran a straight turbo to tail setup before the stacks. The stacks are MUCH better. I HAD to run a resonator with the tailpipe. Even then, all it did was get rid of the drone. Have never needed a resonator with the stacks, even under load.
bmoeller is offline
post #9 of 11 (permalink) Old 05-21-2009, 01:36 PM
Professional Grouch
Live Oak's Avatar
I put the 5 inch straight pipe exhaust on that I got from Fram Boy Diesel Performance. Normal driving and LOW BOOST it is not much louder than stock. You can hear the turbo a lot more and the exhaust sounds like the kitchen sink garbage disposal with the exhaust brake on.
Once you start building boost pressure, especially above 10 psi.........it get kinda LOUD.
Mine-2002 2500 SLT Laramie, 4x4, ETH/DEE, F1 Mach 1.6 injectors, Edge EZ, Cummins eBrake, Air Dog 150, ISSPRO Gauges,BHAF, Outterware Prefilter, heat shield, DSS, Dark Garnet Red, 3.54 diff. gears, Westin Sportsman Brush Guard, Westin Sportsman Nerf Bars, Rhino Liner, White Night backup Light, 295/75R-16's, Passport 8500i radar/laser detector. NRA Benefactor Life Member, NAHC, NSSA, NSCA Life Member, RWVA Member
Hers-2001.5 2500 SLT Laramie, 4x4, ETH/DEE, 3.54 diff. gears, Vulcan 1/2" Big Line Kit w/frame relocated Aertex lift pump, ISSPRO fuel pressure gauge, Side Trax Nerf Bars, Bed Liner, B&W Turnover Ball Hitch, Delta Aluminum Bed Box, Design Tech 50 watt backup lamps.
Live Oak is offline
post #10 of 11 (permalink) Old 05-22-2009, 09:30 PM
My brother straight piped his (02 quad, LB) stock exhaust and you could hear him 2 miles away. Always knew when he has home. Cab noise wasn't bad though. A banks 4 in. straight gets real bad in the cab though.
#23 B.O.M.B. Squad[/B]
rwhite is offline
5" straight pipe *2GLAMIS* 2003-2007 6.0L Power Stroke 7 04-27-2008 06:40 AM
exhaust: straight pipe vs. kit wannadiesel Dodge Performance Forum 5 11-25-2007 01:47 PM
4" MBRP Cool duals resonator delete pipe POWER STROKE 99 Supporting Vendors Forum 1 07-16-2007 07:52 PM
5" Straight Pipe on 7.3 Logan Ford - Modification instructions, Product installs and Tech Articles 8 06-12-2007 05:32 AM
Straight Pipe Shorty Exhaust ? Katmandu General Dodge Discussion 3 01-14-2007 07:29 AM
