"TUNNEL RAM" 24v intake - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TURBOLVR, this thread has received 26 replies and been viewed 8576 times.
Closed Thread
post #1 of 27 (permalink) Old 10-15-2009, 01:39 AM Thread Starter
TURBOLVR's Avatar
Anyone seen this before? Causing quite a stir on other boards!
The stock plate is on the right, not hard to see why the left one flows better!
98.5 CSTD QCSB 4x4
Whipple/Turbonetics chargers,
7x12 stix, .093 lines & tubes
built P-pump,
TUNNELRAM 24-P intake plate,
HBX IC,
PDI T4 3-pc.
O-rings w/mild port&polish
ARP studs
H2 cam
HD pushrods/springs
NE Performance Billet auto,
custom intake horn, grid delete,
electric fans,
leveled by HELL BENT STEEL,
Thuren trac bar,
DSS braced,
RUK control arms,
custom traction bars,
5" duals.
TURBOLVR is offline
post #2 of 27 (permalink) Old 10-15-2009, 01:53 AM
WHOS NEXT
Very nice very nice. No I haven't seen that yet but I have been seriously considering a replacement intake from zz custom fab. So I could port the head better. That would be a step towards bwetter flow untik I'm ready to pull the head again and mill the intake off. Where did you see this?
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #3 of 27 (permalink) Old 10-15-2009, 01:57 AM Thread Starter
TURBOLVR's Avatar
It will bolt to the top of the ZZ intake too! just like the stock plate.
PM for details!
98.5 CSTD QCSB 4x4
built P-pump,
HBX IC,
PDI T4 3-pc.
ARP studs
H2 cam
HD pushrods/springs
electric fans,
Thuren trac bar,
DSS braced,
RUK control arms,
5" duals.
TURBOLVR is offline
post #4 of 27 (permalink) Old 10-15-2009, 04:29 AM
Ghost
Phily's Avatar
Not really. Anyone willing to invest in a better intake is better off figuring out how to center it and then increasing the flow.
How's the P7100-VP44, hybrid/wet dream coming?
Phily is offline
post #5 of 27 (permalink) Old 10-15-2009, 04:53 AM Thread Starter
TURBOLVR's Avatar
Half a brain would give you the ability to know that the CAC tube alignment and hood clearance, heater grids, injection lines, TPS, ect. dictate the design and location as it is. The flow path IS straight into the head and is as large as possible while maintaining clearance and strength.
Please feel free to do it better YOURSELF, or STFU and go pee on someone else's parade! There are precious few who are forwarding the diesel concepts from BS to reality, and YOU contribute NOTHING @ the reality end of the spectrum.
Pump IS in development. Thanks for asking.
98.5 CSTD QCSB 4x4
built P-pump,
HBX IC,
PDI T4 3-pc.
ARP studs
H2 cam
HD pushrods/springs
electric fans,
Thuren trac bar,
DSS braced,
RUK control arms,
5" duals.
TURBOLVR is offline
post #6 of 27 (permalink) Old 10-15-2009, 06:02 AM
so how well does it work?
01quadcab is offline
post #7 of 27 (permalink) Old 10-15-2009, 06:06 PM Thread Starter
TURBOLVR's Avatar
I have been testing one for over a year with a few different turbo/injector/box combos and it has helped control top-end EGTs and aided in spooling as well as evening up the EGTs between cylinders. Here is a shot of my stock plate before I changed it out, its easy to see why the Tunnel Ram flows better.
98.5 CSTD QCSB 4x4
built P-pump,
HBX IC,
PDI T4 3-pc.
ARP studs
H2 cam
HD pushrods/springs
electric fans,
Thuren trac bar,
DSS braced,
RUK control arms,
5" duals.
TURBOLVR is offline
post #8 of 27 (permalink) Old 10-16-2009, 01:51 AM
Someone has too much time on their hands.
Carbur8tr is offline
post #9 of 27 (permalink) Old 10-16-2009, 03:55 AM
Ghost
Phily's Avatar
http://www.competitiondiesel.com/for...ad.php?t=41100
Read the whole thread. Good stuff.
No real progress. I have been too busy building stuff and replacing head gaskets (#3 so far!) to do any worth while work on it. Machine shop is moving into a new building next month too. Still on-going, just s l o w .
Phily is offline
post #10 of 27 (permalink) Old 10-16-2009, 04:43 AM Thread Starter
TURBOLVR's Avatar
I particularly enjoyed YOUR wonderful and insightful contributions to it...
"subscribing"
"Why the hell would you resurrect this ****thread"
"I know exactly where you're coming from. I'm gonna start some "Hot Dog Tree grow" threads and "Tips for talking to Aliens" threads."
"Build the pump, really."
I have read many of your posts on a couple different boards and You dont seem to use the same "charming wit" you like to add to my threads.
Is there any particular reason you feel it is necessary to heckle me?
I dont recall flaming any of your threads.
98.5 CSTD QCSB 4x4
built P-pump,
HBX IC,
PDI T4 3-pc.
ARP studs
H2 cam
HD pushrods/springs
electric fans,
Thuren trac bar,
DSS braced,
RUK control arms,
5" duals.
TURBOLVR is offline
Closed Thread
2001 F250 Crossover Steering & Adjustable Track Bar w/ 10" high (8" lift+2" shackles) kcrowe 1994-2003 7.3L Power Stroke 0 07-02-2009 06:37 PM
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 02:53 PM
94-02 cummins intake horn "IANTAKE" IC Smoke Whats Been Sold 0 03-20-2008 03:20 AM
Intake manifold "cleaning" Spindrift 2003-2007 6.0L Power Stroke 3 01-29-2007 12:38 AM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
