anyone? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Brand-Xrugger, this thread has received 6 replies and been viewed 479 times.
post #1 of 7 (permalink) Old 10-15-2009, 08:51 PM Thread Starter
anyone?
Anyone ever use an intake heater delete? and if you have does if really help with the boost at all?
Brand-Xrugger is offline
post #2 of 7 (permalink) Old 10-15-2009, 10:12 PM
TDG Mafia
Jeffybuilt's Avatar
Not to hijack...but also, will the truck be much harder to start in the cold?
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 7 (permalink) Old 10-16-2009, 02:38 AM
Truck will be very hard to start in cold without it. for all the headahes it causes, it is not worth the extremly small power increase.
hin0031 is offline
post #4 of 7 (permalink) Old 10-16-2009, 02:55 AM
some gain 1-2 hp and some gain none it's not worth it.
01quadcab is offline
post #5 of 7 (permalink) Old 10-16-2009, 03:08 AM
Singles Club #2
smokndiesel7588's Avatar
from what I understand, it becomes more beneficial as you get into the high hp numbers (800+hp)...I believe I heard you gain about 15-20hp when your truck gets into that range
very little gains when under 500hp
Greg
smokndiesel7588 is offline
post #6 of 7 (permalink) Old 10-16-2009, 04:44 PM
well I know that the diesel power challenge 08 winner was still running his. You would see a lot more threads about it if it was gaining that much power on big number trucks. It's all now just a sales gimmick to get people to buy it.
post #7 of 7 (permalink) Old 10-18-2009, 02:52 PM
2nd Gen Guru
Mopar1973Man's Avatar
I've heard the same thing a gain of roughly 15 HP...
As for me I just disconnect the grid heaters so they don't work during the summer there is no need for them... Once the weather is cold (below 32*F) then I hook them up. I do lots of short driving and this does reduce the recharge time on the batteries.
Mopar1973Man is offline
