Block Heater - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummings24v, this thread has received 4 replies and been viewed 1208 times.
post #1 of 5 (permalink) Old 10-19-2009, 01:02 AM Thread Starter
Cummings24v's Avatar
Block Heater
So my truck sits at home all week while i drive the company truck. Should I leave the truck plugged in all week? Any down sides to this?
Thanks
Pat
99 2500, NV4500
4" to 5" pipe, custom made
Edge Comp
BHAF
Raptor 150
EGT, Fuel, Turbo, Oil pressure gauges
285x75x16 Destination MT's
2 stroke oil diet
Cummings24v is offline
post #2 of 5 (permalink) Old 10-19-2009, 01:11 AM
bmoeller's Avatar
If it is the stock heater, you won't hurt anything but your wallet. If you have an idea on how long it will sit, and when you'll drive it again, you could just use a programmable timer.
If it is a 1500 watt heater, then I wouldn't leave it plugged in for more than an hour 2 if it doesn't have a thermostat to turn it off when hot, depending on how cold it was.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 5 (permalink) Old 10-19-2009, 01:35 AM Thread Starter
I believe its a stock heater. Why would it hurt my wallet to plug it in? electricity? Where can i find a programmable timer and how does that work? Thanks!
99 2500, NV4500
Edge Comp
BHAF
Raptor 150
2 stroke oil diet
post #4 of 5 (permalink) Old 10-19-2009, 03:17 AM
bmoeller's Avatar
Yep, electrical cost.
The timer just plugs in to the outlet before the extension cord. The electronic ones work the same as a programmable thermostat in your house. I don't use the mechanical ones. No worries about it breaking any plastic parts in severe cold.
Needs to be good for about 15 amps to cover your butt.
bmoeller is offline
Cummings24v (10-19-2009)
post #5 of 5 (permalink) Old 10-27-2009, 03:13 PM
2nd Gen Guru
Mopar1973Man's Avatar
I just use my high idle...
http://mopar.mopar1973man.com/tips/c.../high-idle.htm
Don't cost anything but the fuel to run the engine... I'll have 170*F of coolant temp in under 10 mintues...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
Cummings24v (10-28-2009)
Block heater? MART5.9 5.9L Cummins (2003-2007.5) 15 04-14-2009 12:27 AM
Block Heater volwing 2008-2010 6.4L Power Stroke 21 01-27-2009 08:45 PM
block heater pgmack 1994-2003 7.3L Power Stroke 4 01-03-2008 01:48 AM
do you have to have a block heater? sprovince 5.9L Cummins (2003-2007.5) 3 11-15-2007 05:12 PM
Block Heater. Where is it? Jakkle5 2003-2007 6.0L Power Stroke 6 01-16-2006 12:39 AM
