little please... indicator - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rlk200469, this thread has received 2 replies and been viewed 441 times.
post #1 of 3 (permalink) Old 10-23-2009, 02:33 AM Thread Starter
i have a 02 dodge 2500. couple of days ago i had a alarm put in. well i got in my truck to leave i notice that when i put the shifter indicator in drive it went further then usual.. well i told the guy that did the alarm and he said it was like that when he pulled it in which i know it wasn't like that.. so when the shift indicator is in p it is really in r. when it is in r it is in drive.. does any body know what it would be the problem???? please help
rlk200469 is offline
post #2 of 3 (permalink) Old 10-24-2009, 02:35 AM
There is an adjustment if you drop the little kick panel under the steering column. Thats where the alarm was installed on my truck. Quite possible that they bumped it trying to get the alarm in. Drop it down and you can see how to adjust it. I don't really remember cecause I've only done it once.
post #3 of 3 (permalink) Old 10-26-2009, 12:48 AM Thread Starter
ill try it and see thanks for the help
Low Engine Oil Level Indicator Always On ripmf666 GM Spec Info 0 12-28-2008 11:25 AM
Oil Change indicator Dodge Guy 6.7L Cummins (2007.5-2011) 3 11-13-2007 02:35 AM
flasher/indicator relay Mad Dog Cycles General Dodge Discussion 2 04-05-2007 10:25 PM
Transmission Gear Indicator gasco Duramax 2001-2004 (LB7) 4 01-08-2007 07:15 PM
Flashing overdrive indicator? JamesF250 1994-2003 7.3L Power Stroke 11 07-03-2006 05:41 AM
