99 24 valve diesel surging - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jkz3883, this thread has received 12 replies and been viewed 15602 times.
post #1 of 13 (permalink) Old 10-25-2009, 11:53 PM Thread Starter
Hello everyone hope all is going to have a good halloween and thnx giving
I have a 99 dodge 24 valve and recently replaced the inj pump and lift pump because the truck was surging. It is really bad between 40 and 60 mph but does do it a little bit sometimes at 70 mph. The dealer ship replaced the inj and lift pump after troubleshooting it with diagnostic equip the first time. They told me they were 100% positive that would fix it. It has only been 1000 miles and the problem is back. Does anyone have any ideas what could be causing this? My gut says electrical or transmission not fuel but this is my first diesel.
thnx
jkz3883 is offline
post #2 of 13 (permalink) Old 10-27-2009, 03:21 PM
2nd Gen Guru
Mopar1973Man's Avatar
Lets start with simple information...
What's your fuel pressure like?
http://mopar.mopar1973man.com/tips/c...l-pressure.htm
Got any error codes? (You'll need a code reader)
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
Fuel pressure is everything to these trucks. Then the error codes will tell you exactly what is failing to bugging the truck.
Mopar1973Man is offline
post #3 of 13 (permalink) Old 10-31-2009, 05:42 PM Thread Starter
surging
Thanks for the links for troubleshooting. I will have to check the fuel pressure.
The dealer ship just replaced my inj pump and lift pump 1,000 miles ago and it still does the surging. Does it worse at 45 mph range. I don't have any engine lights or anything on but I will get codes read.
can I use a paper clip and jump the prongs in the obd plug under dash by ashtray to get the codes manually without a code reader?
I am in the Army and go to the field next week so it will be next weekend before I am able to let you know what I find out.
I kind of think it is something to do with the transmission cuz to me it acts like it can't make up its mind on whether or not to shift gears or not.
wut do you think?
Thnks for your help and I will keep you informed.
jkz3883 is offline
post #4 of 13 (permalink) Old 10-31-2009, 08:29 PM
2nd Gen Guru
Yeap fuel pressure has a bearing on performance...
Check engine light doesn't come on for every error code. So read my write and it will tell how to get your error codes...
Ummm... Either the key trick or the code reader... This is not a Chevy...
wut do you think?
Error codes might give a clue... Once you have them you might have some information on what had failed.
Comments in blue...
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
scott100r (01-12-2010)
post #5 of 13 (permalink) Old 11-09-2009, 02:46 AM
bmoeller's Avatar
Autozone lets you use a code reader for free at the store.
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 13 (permalink) Old 11-26-2009, 05:48 PM Thread Starter
Fuel pressure is good. Dealer ship said it is tps but they were wrong. picked it up and still does it.
I really think it has something to do with the transmission. It acts like it can't decide to shift or not. It takes forever for it to shift at 2nd and 3rd when accelerating normal. Once I am at 45 plus mph it goes back and forth in and out of gear (like a surge) fluctuating about 4 or 5 hundred rpms. Kind of like a torq convertor, shift solenoid, or something.
Help pls I am tired of dealing with dealer ship who apparently knows jack crap.
thnx and happy thnx giving
jkz3883 is offline
post #7 of 13 (permalink) Old 11-27-2009, 04:14 AM
bmoeller's Avatar
Sounds like the transmission is hunting in and out of O/D. A known problem. My '99 has a NVG, so no worries for me.
bmoeller is offline
post #8 of 13 (permalink) Old 11-27-2009, 10:21 PM Thread Starter
Wut causes it to hunt in and out of o/d?
Wuts an NVG?
jkz3883 is offline
post #9 of 13 (permalink) Old 11-28-2009, 01:02 PM
99 cummins
customdeluxe78's Avatar
the key trick wont work, its a 99
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
post #10 of 13 (permalink) Old 11-29-2009, 02:59 AM
bmoeller's Avatar
At a bad RPM range. Computer can't decide what gear to be in, or if the t/c lock up clutch should be engaged. Locking the O/D out prevents the hunting. Also, low RPMs and very light throttle pedal means low line pressure in the transmission, which leads to premature transmission failure. Not enough pressure to prevent the clutch packs from slipping.
Wuts an NVG?
New Venture Gear. They made the 4500 (5spd) and 5600 (6spd) manual transmissions used in our trucks and others. I have the 4500.
bmoeller is offline
6.0 Ford diesel surging, not lurching though Barn Dude 2003-2007 6.0L Power Stroke 11 06-10-2013 10:39 AM
1989 12 valve Cummins diesel motor forsale robs11260 Whats Been Sold 2 02-02-2008 12:31 AM
Hamilton Diesel 24V Upgraded Valve Springs! DPDIESEL Supporting Vendors Forum 5 09-21-2007 04:49 AM
New to diesel trucks..Is the cummins 12 valve right for me? NSXnTruckguy 5.9L Cummins 12 Valve (1994-1998.5) 39 04-30-2007 12:13 AM
SCT before surging 6L strokin 2003-2007 6.0 Tuner Forum 4 03-02-2007 02:27 PM
