injectors? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blowin smoke 1, this thread has received 10 replies and been viewed 1178 times.
post #1 of 11 (permalink) Old 10-27-2009, 09:22 PM Thread Starter
injectors?
Will 150 injectors kill the life of my engine?
blowin smoke 1 is offline
post #2 of 11 (permalink) Old 10-28-2009, 12:07 AM
TDG Mafia
Jeffybuilt's Avatar
That is an open question...
Some things you need to remember: When you add more fuel, you need to add more air. You need to keep your EGT's in check so you don't go and do major damage.
You also need adequate fuel supply to feed the injectors, as they will be capable of flowing a lot more fuel, they will need more fuel to be availible to them at the proper pressure.
That help?
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 11 (permalink) Old 10-28-2009, 02:50 AM Thread Starter
injectors
I have a super b,5" exhaust edge juice bd supply pump.When i put the edge on the truck egt went crazy.I hit a deere in the next week so i put the bd intercooler on it.The turbo fixed the egt.The injectors are ddp 150s havent put them on yet was just wondering about the life of my motor with this extra add ons.Thanks
post #4 of 11 (permalink) Old 10-28-2009, 02:57 AM
TDG Mafia
Jeffybuilt's Avatar
That all sounds pretty good to me. I'm not the best authority on turbos, there are some guys on here that are real good about that stuff. Sean, or sstockton on here could give you some good advice.
From what I know....I would say they should be just fine, and it sounds like you already keep an eye on your EGT's and the like, so I would say go for it. As long as you watch your gauges, I dont see a problem with the "life of the motor" I would be more worried about the fuel system. Do you happen to have a fuel pressure gauge? I do not know what the BD pump will support. I thought it was just kind of an upgraded Carter style pump....
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #5 of 11 (permalink) Old 11-01-2009, 03:59 PM
turbo and injectors will match up well, but I have heard the bd supply pump doesn't handle as well as most people like.
01quadcab is offline
post #6 of 11 (permalink) Old 11-05-2009, 01:59 AM
That turbo is a little small for 150's. The Super B special would handle 150's a bit better. As for the life of your engine being shortened by the injectors. Not really. If you mind your EGT's and boost, and keep up on the general maintenance, it will be just fine.
post #7 of 11 (permalink) Old 11-06-2009, 02:32 PM Thread Starter
Do you think I should send them back for some smaller ones?I drive at least a 130 miles a day.Thanks
post #8 of 11 (permalink) Old 11-07-2009, 04:38 AM
Depends on how you drive. You just won't really be able to maximize the injectors with that turbo.
post #9 of 11 (permalink) Old 11-16-2009, 04:41 AM
I've been running the edge 150's for about 2 years now with the super b and no trouble. I agree with sstockton it just depends on how you drive. I keep my foot on the old man setting most of the time. I would certainly look for a big supply pump, they are thirsty injectors. Oh and get used to higher egt's mine are around 900 running down the road
StrokeThisGoat is offline
post #10 of 11 (permalink) Old 11-25-2009, 02:42 PM
2nd Gen Guru
Mopar1973Man's Avatar
Wow! That is a bit hot...
By chance what kind of MPG's are you seeing with that setup now?
Mopar1973Man is offline
Looking for a set of 250 cc or bigger injectors in trade for my II 185 cc injectors mikes06lariat Ford Parts wanted 1 08-12-2009 02:52 AM
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
Injectors? TheNightmare 5.9L Cummins 12 Valve (1994-1998.5) 2 03-30-2008 03:34 AM
Help Injectors?????? strokedout_07 2003-2007 6.0L Power Stroke 18 04-20-2007 04:20 AM
Injectors imported_smokindodge12v 5.9L Cummins 12 Valve (1994-1998.5) 3 04-16-2007 03:28 PM
