Opinions? (new to Cummins) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Turbojoey, this thread has received 7 replies and been viewed 1115 times.
post #1 of 8 (permalink) Old 10-30-2009, 12:45 PM Thread Starter
http://scranton.craigslist.org/cto/1406170373.html
Hello all,
I am looking at this truck. I dont know much about Cummins/Dodge tuning...yet...but I am seeking feedback on this add as to if you "experts" think it sounds like a good setup. I did email the seller and he filled me in on his routine maintenance and problems he had with the truck such as the typical IP replaced 2 years ago, oil changed every 3k, light leak around front axle seal, fuel filter changed every 6k...
Thanks in advance for any help!!!
Joe
Turbojoey is offline
post #2 of 8 (permalink) Old 10-30-2009, 02:21 PM
Official TDG Doctor
hccumminssmoke's Avatar
Id ask to see all his recipts...Not sure what things go for up there but if you could pick it up between 12-13 id think it would be a good buy...
Nate
hccumminssmoke is offline
The Following User Says Thank You to hccumminssmoke For this addition to TDG:
Turbojoey (10-30-2009)
post #3 of 8 (permalink) Old 10-30-2009, 04:18 PM
Singles Club #2
smokndiesel7588's Avatar
$14500 isnt a bad price for that truck...I paid $16k for a stock 2002 with 113k miles 2 years ago and I had found mine a little NE of scranton...if you could talk him down $500-1000 that would be a good deal
Greg
smokndiesel7588 is offline
The Following User Says Thank You to smokndiesel7588 For this addition to TDG:
post #4 of 8 (permalink) Old 10-30-2009, 04:31 PM
ADMIN/MAFIA
neeltburn's Avatar
I agree with what Nate said, and ask to see all receipts. I ran it through KBB quickly here is the link (if it works) http://www.kbb.com/KBB/UsedCars/Pric...uizConditions=
I would just be sure it doesn't seem to be abused, and then make him an offer as others have said.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 8 (permalink) Old 10-30-2009, 08:07 PM
M123KT-450's Avatar
Buy it ! . . . buy it ! . . . buy it ! . . . you buy it yet ?
Truck looks fantastic, I would definitely go for it . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
The Following User Says Thank You to M123KT-450 For this addition to TDG:
post #6 of 8 (permalink) Old 10-31-2009, 06:40 PM
Be careful and check for receipts as hc said, drive it and make sure you check codes. Find out what kindof tranny is in there cause that could be a costly figure down the road if it wasn't done right the first time.
Carbur8tr is offline
post #7 of 8 (permalink) Old 10-31-2009, 07:42 PM
WHOS NEXT
yeah i would wanna see reciepts, and find out exactly what was done to the tranny and who did it. but if everything is legit then id buy it. she looks nice and clean and well taken care of.
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #8 of 8 (permalink) Old 10-31-2009, 08:25 PM
2nd Gen Guru
Mopar1973Man's Avatar
I would see want kind of fuel pressure the truck got and check for error codes... Remember Auto trans are the weakest trans that a Cummins could have...
http://mopar.mopar1973man.com/tips/c...l-pressure.htm
http://mopar.mopar1973man.com/tips/c...rror-codes.htm
Mopar1973Man is offline
need some opinions Dieseldemon61 5.9L Cummins 12 Valve (1994-1998.5) 5 02-19-2009 12:46 PM
Need opinions on my cummins half ton Morse The Parking Lot 1 04-11-2006 10:08 PM
Opinions please Unbroken The Parking Lot 23 11-24-2005 04:38 PM
Opinions on 78 Powerwagon 12v Cummins Swap Strictly gravy General Dodge Discussion 6 11-14-2005 08:05 PM
