late shift to 2nd - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummings24v, this thread has received 5 replies and been viewed 683 times.
post #1 of 6 (permalink) Old 10-30-2009, 07:59 PM Thread Starter
Cummings24v's Avatar
late shift to 2nd
The other day I took off from a stop sign.. half throttle.. truck made its first shift fine around 2100rpm and then would not shift to 3rd untill i backed off the throttle. From that point on it does the same damn thing. If i just ease it through the gears its fine and does not slip once in high gear and i pour on the power. Fluid and filter was changed about 8k ago. I do not see any leaks. Tranny was rebuilt to its stock form at 98k. It now has 133k. Scanned for codes.. nothing..I believe it might still be under warrenty but just wanted some other inputs. Thanks guys. If i do bring it to the tranny shop i should probably take the juice off her...right??
-Pat
99 2500, NV4500
4" to 5" pipe, custom made
Edge Comp
BHAF
Raptor 150
EGT, Fuel, Turbo, Oil pressure gauges
285x75x16 Destination MT's
2 stroke oil diet
Cummings24v is offline
post #2 of 6 (permalink) Old 10-30-2009, 11:41 PM
I would check the shift selinoids. they may not throgh codes and even ohm fine but cause problems like that mine did about 3 weeks ago right after I had the tranny built.
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #3 of 6 (permalink) Old 11-01-2009, 04:00 PM
tv cable may be a hair tight
01quadcab is offline
post #4 of 6 (permalink) Old 11-02-2009, 12:12 PM
bmoeller's Avatar
Could be a governor pressure solenoid or gov pressure transducer issue. Easy to replace. Cost ~$100/ea.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 6 (permalink) Old 11-02-2009, 09:53 PM Thread Starter
thanks guys!! were are the shift solenoids located?
99 2500, NV4500
Edge Comp
BHAF
Raptor 150
2 stroke oil diet
post #6 of 6 (permalink) Old 11-11-2009, 09:15 PM Thread Starter
definatly not anything simple... pan was full of metal! Can have her re-built stock for around 1000, family friend. But who wants stock. Looking at my options now!!!
99 2500, NV4500
Edge Comp
BHAF
Raptor 150
2 stroke oil diet
SCT User Adjustments (WOT Speed Shift & Shift Pressure) ebusa 2003-2007 6.0 Tuner Forum 1 04-29-2008 03:23 AM
Torq Shift Flare 2-3 shift, when cold SICKS-O 2003-2007 6.0L Power Stroke 15 12-31-2007 03:41 PM
Please help before its too late seven.three 1994-2003 7.3L Power Stroke 3 11-17-2007 12:28 AM
Is it too late for my dog??? KarTek The Parking Lot 10 04-26-2006 02:35 AM
