Front differential? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01CUMMINS24, this thread has received 4 replies and been viewed 827 times.
post #1 of 5 (permalink) Old 11-02-2009, 12:27 PM Thread Starter
01CUMMINS24
Front differential?
Yesturday i noticed there was oil on the frame and fender well on the passenger side. It was 90 weight. Found that it was coming from the breather on my front diff. Last time i checked it, it was at the right level. Have done nothing to it since. I dont see how the oil is traveling all the way up the breather hose unless it has alot of pressure in diff. Has anyone had this problem or know of anything i can check?
01CUMMINS24 is offline
post #2 of 5 (permalink) Old 11-02-2009, 06:08 PM
2nd Gen Guru
Mopar1973Man's Avatar
Re check the fluid and make sure there isn't water in it... That the only thing I can think of...
Mopar1973Man is offline
post #3 of 5 (permalink) Old 11-04-2009, 10:59 PM Thread Starter
01CUMMINS24
I checked the oil and it is low, can't even touch oil with my finger. Is there any way that the vaccum thing on the axle is causing it to pressure up?
post #4 of 5 (permalink) Old 11-05-2009, 12:47 AM
That wouldn't cause that. The vacume diaphram is sealed and only actuates the 4 wheel drive, if the the diaphram did leak it wouldn't affect the gear oil, 4x4 just wouldn't work.
cumminsdude2001 is offline
post #5 of 5 (permalink) Old 11-10-2009, 01:20 PM
2nd Gen Guru
If it was me I would pop the cover off and drain and reload both front and rear axle with fresh gear oil.
FS: front Dana D60 differential cover jvencius Ford Parts 0 09-09-2009 11:18 PM
F-450 front differential & sway bar pics plainredtruck 1994-2003 7.3L Power Stroke 0 06-25-2009 02:13 PM
Front differential jeffro22 General Ford Truck and Excursion 2 01-27-2009 01:16 AM
Differential question strokin350 1994-2003 7.3L Power Stroke 8 05-02-2007 01:21 PM
Front Differential Options Diesel Dave 7.3L and 6.9 IDI (Pre 1994) 3 04-02-2007 02:54 AM
