1999 2500 Dodge ram ecu flashing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by srkposton, this thread has received 5 replies and been viewed 5670 times.
post #1 of 6 (permalink) Old 11-02-2009, 04:33 PM Thread Starter
Unhappy 1999 2500 Dodge ram ecu flashing
Ok this might be a dumb question. I just got a 1999 dodge ram 2500. I know that the speedo is controlled buy the ecu. I have 35" tires on it. I also know that you can change tire sizes from the ecu it doesn't have that tire size so my question can you flash the ecu to an 01 which has all of the different tire sizes?
srkposton is offline
post #2 of 6 (permalink) Old 11-02-2009, 06:06 PM
2nd Gen Guru
Mopar1973Man's Avatar
Actually no...
ECM = Engine Control Module
PCM = Powertrain Control Module
Actually the ABS computer is want requires the flashing and there is only a few ways of dealing with it. Using a programmer like SuperChips or Smarty or going to the local Dodge Dealer for the re-calibrate.
The ABS computer needs the calibration for proper braking function then the speed information is passed by CCD network to the PCM for the Intrustment Cluster for speedmeter display.
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
srkposton (11-03-2009)
post #3 of 6 (permalink) Old 11-03-2009, 12:21 AM Thread Starter
Thanks
I just wanted to say thanks for that information. I will totally give it a try.
post #4 of 6 (permalink) Old 11-04-2009, 05:01 PM
my local shop did my recalibration on my 01 you needed to know revolutions per mile I think or something like that.
01quadcab is offline
post #5 of 6 (permalink) Old 11-10-2009, 01:06 PM
2nd Gen Guru
Most tire shops can give you the revs/mile number.
post #6 of 6 (permalink) Old 11-11-2009, 03:56 PM
yeah or any tire ship online too. It's in the specs. It worked fine on my 01. The 99 is going to get some work now too. It's off by a lot. 35's on it calibrated to stock still.
1999 Dodge Ram 2500 Spindrift Whats Been Sold 2 06-14-2009 05:42 PM
1999 Dodge Ram 2500 Pulling Truck ruffmanatv Whats Been Sold 8 02-22-2009 12:42 PM
1999 Dodge Ram 2500 hcr400ex Whats Been Sold 1 01-13-2008 07:21 PM
1999 Dodge Cummins 2500 4x4 Hoob Whats Been Sold 1 09-13-2007 06:49 PM
1999 Dodge 2500 Cummins lbdodge24v 5.9L Cummins (1998.5-2002) 8 08-30-2007 01:00 AM
