how to set valves - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kennyhammond, this thread has received 3 replies and been viewed 3987 times.
post #1 of 4 (permalink) Old 11-07-2009, 01:21 AM Thread Starter
how to set valves
i am trying to find the specs on the seeting of the valves for a 2002 dodge ram 3500 cummins non HO 5 speed and does anyone know a cheap place i can get a air dog or fass lift pump for my truck i think my stock lift is going south!!!
kennyhammond is offline
post #2 of 4 (permalink) Old 11-07-2009, 04:32 AM
Are you looking for the valve lash specs? Like what to adjust your valve clearances too. Or are you looking for the seat angles and minimum and maximum width etc...
Intake lash spec is .010"
Exhaust lash spec is .020"
With engine at TDC adjust:
Intake 1,2,4
Exhaust 1,3,5
With engine at BDC adjust:
Intake 3,5,6
Exhaust 2,4,6
Intake seat angle is 30*
Exhaust seat angle is 45*
Minimum seat width is .059"
Maximum seat width is .071"
Hope this helps.
post #3 of 4 (permalink) Old 11-07-2009, 08:37 PM
both fass and airdog only allow their distributers to sell their products for X ammout and if they get cought selling below that minimum then they lose their rights to sell either of them. so the best price for an airdog right now is 499 and thats the airdog 150 the 100 is the same(so why not get the bigger one) the raptors are cheaper but if you are spending that much on a pump already i figured i would just get the better one. and i wouldent go with fass because they are really loud and you can hear them in the cab with the motor running. the airdog is cheaper(about 200$) and it comes with 1/2" lines, and a draw straw and i can barly hear is when i turn the key on and i cant hear it at all when the motor is running. the fass comes with 3/8" lines and i dont think it comes with a straw.
and the fass is huge compared to the airdog. dimensonally the fass is a lot bigger.
04 PowerStrokE is offline
post #4 of 4 (permalink) Old 11-10-2009, 01:01 PM
2nd Gen Guru
Mopar1973Man's Avatar
Here is my write up on that...
http://mopar.mopar1973man.com/tips/c.../valve-adj.htm
Mopar1973Man is offline
Spool Valves StrokerDude 2003-2007 6.0L Power Stroke 9 09-14-2009 10:41 PM
94-98 12 valves Cummins5390 5.9L Cummins 12 Valve (1994-1998.5) 8 12-10-2007 07:25 PM
Valves are scored Okie2500 5.9L Cummins (1998.5-2002) 7 04-10-2007 06:15 AM
Pop off valves?? tahoedmax Duramax 2001-2004 (LB7) 14 02-21-2007 04:28 AM
New to 24 valves! CanadianCarGuy 5.9L Cummins (1998.5-2002) 10 02-07-2006 01:33 AM
