Loose brake rotor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Carbur8tr, this thread has received 5 replies and been viewed 1076 times.
post #1 of 6 (permalink) Old 11-07-2009, 02:22 PM Thread Starter
Loose brake rotor
Well as it says, my front left brake rotor is a little loose. I tried to look in my Haynes book but I couldn't really find anything. I'm a little concerned but not to much seeing as though when I tighten the wheel back down it tightens up, but none-the-less I still would like to get it tight on there. Any suggestions?
Carbur8tr is offline
post #2 of 6 (permalink) Old 11-08-2009, 02:57 AM
Well, since they are trapped by the wheel, and then the lug nuts are used to tighten the whole assembly I wouldn't be worried at all. Thats the way the pretty much all work. If they've been on for a while, then they tend be stuck on a little more.
post #3 of 6 (permalink) Old 11-09-2009, 01:26 AM Thread Starter
That was pretty much my thought but just wanted to make sure that all is well. Thanks
post #4 of 6 (permalink) Old 11-10-2009, 01:09 PM
2nd Gen Guru
Mopar1973Man's Avatar
Ok... I got something to check...
Most tire shops will toss the tire on and the hand spin all the lug nuts on a few turns the zap them down with a impact gun. Dodge rotors are know to get off center if done this way. I will hand tighten 2 or 3 nuts evenly and then got to it with the impact gun.
So try backing them off and start with 2 or 3 nuts and tight by hand to seat the wheel again the rotor...
Mopar1973Man is offline
post #5 of 6 (permalink) Old 11-11-2009, 01:33 AM
ADMIN/MAFIA
neeltburn's Avatar
had this happen on my dads 1/2 now I do the exact same thing...seems to work.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #6 of 6 (permalink) Old 11-11-2009, 08:32 PM Thread Starter
Dully noted, Usually I tighten all of them before I get at it with the impact. Just an old habit.
Brake Tab thing hitting rotor brendonv General Ford Truck and Excursion 2 09-25-2009 10:13 AM
Brake rotor noises? Horsehaulin Medium and Heavy Duty 12 04-08-2009 05:27 AM
Front brake rotor questions 99fordtruckguy 1994-2003 7.3L Power Stroke 3 02-11-2008 03:50 AM
Superduty brake rotor size? jvencius General Ford Truck and Excursion 2 01-10-2008 07:07 AM
Rotor and brake pad replacement rum4 General Ford Truck and Excursion 9 08-25-2006 01:32 PM
