edge comp box - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kennyhammond, this thread has received 12 replies and been viewed 2420 times.
post #1 of 13 (permalink) Old 11-08-2009, 04:31 PM Thread Starter
edge comp box
i have a edge comp box and nthis will be the second time that i have ahd my lift pump go out...so i have decided that i am getting rid of my box and going to get somethen a lil milder i will admit i have the bad habit of playen around and cranken that chip up and smoken somepoeple out when they tailgate.....lol so i want somethen mild like 65 or below hp a downloader so i cant mess with it....are there any good ideas and does anyone know a good place to get a airdog or FASS lift pump thanks this site is a realy helpfull site thanks for the help
kennyhammond is offline
post #2 of 13 (permalink) Old 11-08-2009, 05:29 PM
TDG Mafia Goon
BombDocDiesel's Avatar
I wouldn't ditch the Comp. Get yourself an AD 150 and get rid of the fuel filter housing and factory lift pump. Try this: http://www.alligatorperformance.com/...oducts_id=3273
The Comp is probably not eating LPs. The factory ones are just that bad. Mine was great one day and the next day i was sitting at 5-7PSI at idle.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #3 of 13 (permalink) Old 11-08-2009, 05:49 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
I would agree its not the edge but you do need a good lift pump system. But if you are in a cold climate I would not get rid of the stock filter housing because it has a fuel heater in it just ditch the stock filter. You will need to order a few fittings from air dog to use the stock housing. Unless you have a big line kit already
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #4 of 13 (permalink) Old 11-08-2009, 06:02 PM
TDG Mafia Goon
Good call. I never think about that heater since I don't need them here.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #5 of 13 (permalink) Old 11-08-2009, 11:11 PM Thread Starter
yeah i dout i need the heater also i am in south texas we rarely see any hot weather... how hard is it to put a air dog 150 on mny truck? will it bolt to the factory place? and the all time goal i am trying to do with my truck is to drive it and make it run good but still be very very dependable...... just baught a new house and wont be able to get another new truck until like 4 years (wife makes the rules ) jk well any ideas would be great and thanks for the help (i have a 2002 dodge 3500 NON HO 5 speed with a straight pipe (factory pipe) edge box thats it if you guys can think of anything i should replace or add let me know please..... my email is [email protected] if anyone wants to send me direct
post #6 of 13 (permalink) Old 11-08-2009, 11:20 PM
TDG Mafia Goon
An AirDog 100 or AirDog2 165 will be quicker to install than the 150.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #7 of 13 (permalink) Old 11-10-2009, 01:03 PM
2nd Gen Guru
Mopar1973Man's Avatar
I'm running a AirDog 150 with my Edge Comp no issues the fuel pressure sits at about 15 PSI WOT on 5x5. Then leaving the Edge Comp on 5x5 I'm pulling upwards into 25.3 MPG MAX ans 21-22 MPG AVG.
Keep the Edge Comp it works good!
Mopar1973Man is offline
post #8 of 13 (permalink) Old 11-11-2009, 02:13 AM Thread Starter
how hard are one of these pumps to put on? and is the airdog better than the FASS? i dont have gauges or anything on my truck just box and straight pipe so i dout i can run my box on 5x5 lol but i am super excited to get a good lift pump and feal safe......
post #9 of 13 (permalink) Old 11-11-2009, 02:39 AM
2nd Gen Guru
Airdog is smaller than a FASS...
Get gauges! (Fuel Pressure, Pyrometer, and Boost) You'd be surprised that you can pull some seriously high pyro temps. Don't turn it up till you got gauges...
post #10 of 13 (permalink) Old 11-11-2009, 04:29 PM
Singles Club #2
smokndiesel7588's Avatar
i wouldnt say that the airdog is better than the FASS...I have had my FASS on for over a year now with a smarty and 110hp injectors..at idle I see a consistent 20psi and cannot bring it down below 16-17psi @ WOT...the airdog (as others said) is a bit smaller/quieter...but i can barely hear my FASS over the stack anyways..so it doesnt bother me
but like Mike said...get gauges
Greg
smokndiesel7588 is offline
edge comp or edge juice w/attidue fitz1985 5.9L Cummins (1998.5-2002) 13 10-03-2007 01:43 AM
Edge comp STROKER SMOKER 5.9L Cummins (1998.5-2002) 4 07-03-2007 08:19 PM
Edge Drag Comp vs. Edge Juice/Attitude lbdodge24v 5.9L Cummins (1998.5-2002) 12 03-08-2007 08:31 PM
edge juice and edge comp??? masonjo 24 Valve Performance 19 01-23-2007 11:51 PM
stacked my edge comp with my drag comp today, it hauls butt OFFRODEN 5.9L Cummins (1998.5-2002) 22 11-30-2006 06:43 PM
