upgrading the ground for a vp44 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by okiebindernut, this thread has received 1 replies and been viewed 1502 times.
post #1 of 2 (permalink) Old 11-12-2009, 03:38 PM Thread Starter
I was doing some searching on here about vp44 problems and I saw it mentioned a couple of times to upgrade the ground for the pump because the factory one was not good. How have some of you guys gone about doing this, just curious?
IH 4x4 club member #2
okiebindernut is offline
post #2 of 2 (permalink) Old 11-13-2009, 03:19 PM
2nd Gen Guru
Mopar1973Man's Avatar
The actual ground wire is behind the starter... You must remove the starter for access. But typically it dirty connection that foul things up for VP44, APPS, etc... So keep your battery terminals clean and check the terminal connection for ground...
Actually the problem is mostly for APPS problems for weak grounds...
Mopar1973Man is offline
700 to the ground.... pblankenship Medium and Heavy Duty 5 09-02-2009 03:24 PM
Hot VP44 or Blue Chip's VP44 Mad Dog Cycles 24 Valve Performance 12 05-03-2009 01:38 AM
375hp To The Ground cumminspride 5.9L Cummins (Pre 1994) 11 09-09-2007 12:57 AM
Where can I get a good ground? CBSuperduty 2003-2007 6.0L Power Stroke 3 11-23-2005 06:16 PM
Puller from the ground up? Paul H Sled Pulling 67 08-08-2005 10:47 PM
