Hard Start on 98 truck - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hhrecovery, this thread has received 4 replies and been viewed 879 times.
post #1 of 5 (permalink) Old 11-13-2009, 12:24 AM Thread Starter
MAFIA #8
hhrecovery's Avatar
Images: 1
My buddys truck has an intermittent hard start... He took it to the dealership and they put an inj. pump and lift pump on it but still has the same issue. It acts like it is leaking down. Any ideas???
2003 F250 "Pulling Truck"
hhrecovery is offline
post #2 of 5 (permalink) Old 11-13-2009, 03:54 AM
ADMIN/MAFIA
neeltburn's Avatar
Did they put a new lift pump on it as well?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 5 (permalink) Old 11-13-2009, 03:17 PM
2nd Gen Guru
Mopar1973Man's Avatar
Yeap... Low pressure tore the diaphram in the VP44...
Try this mod...
http://mopar.mopar1973man.com/tips/c...l-pressure.htm
(Bottom of page)
Mopar1973Man is offline
post #4 of 5 (permalink) Old 11-13-2009, 03:28 PM
I don't mean to bust in on this but. My 99 is doing the same thing. Mine only seems to do this when the fuel hand is around a quarter of a tank or on a unlevel grade, only on starting. I have a Fass 95 lift pump and holds anywhere from 15 to 18 fuel pressure. If I touch barely put my foot on the pedal it will start after a few cranks. I have no problems if you turn it off on a grade then start it right back up but after a while, it does it. Any suggestions?
1999 Dodge 2500, 4X4, automatic, with an swapped 53 block with a 2001 55 block, Mods: Edge Juice with Attitude, Sliencer ring MIA, BHAF, 2" leveling kit, straight piped, brush guard.
DHenson is offline
post #5 of 5 (permalink) Old 11-17-2009, 10:00 PM
What about when its facing down hill? Sounds like fuel might be draining back into the tank.
truck hard to start need help please ldwzlaw 1994-2003 7.3L Power Stroke 8 10-04-2009 01:30 AM
Truck hard to start! ACC inc. 2003-2007 6.0L Power Stroke 6 11-28-2007 09:35 PM
Hard to start / white smoke at start, again. bsigg 6.5L Diesel Engine 2 11-27-2007 03:57 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 11:55 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 07:32 AM
