changed engine not charging mpg backwards - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rxpower, this thread has received 5 replies and been viewed 792 times.
post #1 of 6 (permalink) Old 11-18-2009, 01:30 PM Thread Starter
millage on my inside display started displaying in reverse when i decelerate it was showing 99 mpg now it shows 0 mpg drove this way for several hundred miles then! also after changing the engine it quit charging the power for the key on at the alt plug with two pins will power up for 1-2 seconds then goes off when the engine is started the pin is hot for 1 sec more then goes out again. changed ecu no change just changed the wiring harness same problem. had alt rebuilt and re tested on a stand charging ok I'm being told it might be pcu and doge wants $700.00 did not get the codes but check engine light is on, went off when changed the ecu then back on
2001
ram
3500
300,000 miles on original engine
what I have tried: checked the alt on the bench it is charging
changed the euc
tried 2nd wiring harness
checked to see that the battery sensor was plugged in just changed the engine out with one with 74000 miles on it
tested the power at alt two pin plug
rxpower is offline
post #2 of 6 (permalink) Old 11-22-2009, 02:28 PM
bmoeller's Avatar
Is the 120A fuse in the PDC blown?
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 6 (permalink) Old 11-22-2009, 04:38 PM Thread Starter
no the fuse is not blown
rxpower is offline
post #4 of 6 (permalink) Old 11-22-2009, 04:46 PM Thread Starter
the dislpay is working for the miles per gallon I put a new pcm on a different ecm pulled the alt had it bench tested (which is a new alt from parts store) changed the wireing harness back to the one from the orignal truck and engine (just replaced the engine) changed the crank sensor, map sensor, and temp sending unit as I was getting codes on all this when I got all the orignal parts back the codes stopped the pcm did not stop the codes nor solve the alt problem. whail at the dealer having the pcm flashed the teck hit a button on his hand held unit and the alt would charge he said the crank sensor was not sending rpm to the engine although the tack was working at the time so i changed the sending unit when i got home still no chargeing
rxpower is offline
post #5 of 6 (permalink) Old 11-25-2009, 01:35 AM
bmoeller's Avatar
Ya, the PCM has the voltage regulator in it. No crank signal+ no charge. Wiring problem yet, somewhere? You could install an external regulator, if need be.
bmoeller is offline
post #6 of 6 (permalink) Old 11-25-2009, 02:31 PM
2nd Gen Guru
Mopar1973Man's Avatar
The overhead console cannot be recalibrated. These thing are simply junk. I switch over to a ScanGauge II and keep up on the calibration of the SG II and it always really close to the mark!
Mopar1973Man is offline
Backwards Silencer Ring?? Cummins_Beast 5.9L Cummins (2003-2007.5) 11 01-07-2010 10:42 PM
backwards brake lights? bseals Medium and Heavy Duty 1 08-15-2009 08:34 PM
Cummins ran backwards??!! BigRed Cummins 5.9L Cummins 12 Valve (1994-1998.5) 11 06-04-2009 03:50 PM
Pulling 5th Wheel...Backwards????? bigdraft Towing and Hauling 72 03-23-2008 01:28 PM
not charging dirt racer 5.9L Cummins 12 Valve (1994-1998.5) 3 08-18-2006 01:55 AM
