Hard pedal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RobVG, this thread has received 5 replies and been viewed 959 times.
post #1 of 6 (permalink) Old 11-21-2009, 07:12 PM Thread Starter
Hard pedal
2001 170,000mi
Not my truck
Replaced rear rotors, calipers and pads. Bled calipers.
Truck stops good but pedal feels hard to me. It almost feels like there's no power assist.
What could I have done wrong?
RobVG is offline
post #2 of 6 (permalink) Old 11-22-2009, 01:31 AM
bmoeller's Avatar
Did you open up the bleeder screws when you pressed the caliper pistons back in?
Power steering working fine?
"Obama = Hoax and Chains"
bmoeller is offline
RobVG (11-22-2009)
post #3 of 6 (permalink) Old 11-22-2009, 01:50 PM
cowboytw13's Avatar
Mine did the same thing when I replaced the master cylinder, then one day it just started working right. took about two weeks I think. But you're right, it seemed like there wasn't any power assist.
cowboytw13 is offline
The Following User Says Thank You to cowboytw13 For this addition to TDG:
RobVG (11-22-2009)
post #4 of 6 (permalink) Old 11-22-2009, 11:45 PM Thread Starter
Thanks for the responses.
The calipers were new (reman) in the box so the pistons were already seated.
PWR steering works fine.
RobVG is offline
post #5 of 6 (permalink) Old 11-25-2009, 02:35 PM
2nd Gen Guru
Mopar1973Man's Avatar
ABS sensors? If a front sensor is going out and and mis-reading speed signals it will actually push against you for brakes causing a hard pedal.
Another causes is debris in the power steering fluid and it plugged on of the port in the Hydro-booster. You'll need to pull it off and clean and replace. PS fluid is suppose to be changed every 30K miles!
Brake fluid what color is it? If its dark it suppose to be change too.. Brake fluid should be changed every 30K miles too.
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
RobVG (11-28-2009)
post #6 of 6 (permalink) Old 11-28-2009, 06:59 PM Thread Starter
Problem is, I think it was working ok before I changed the calipers. Haven't heard any feedback from the driver, will see him Monday.
RobVG is offline
Hard Brake Pedal but No Brakes!! Help! DINOONE 2008-2010 6.4L Power Stroke 11 07-02-2009 01:25 PM
tps pedal testing camojeeper 1994-2003 7.3L Chips & Tuners Forum 2 01-10-2009 03:58 AM
the dead pedal MOOSE 04 5.9L Cummins (1998.5-2002) 9 12-19-2007 12:56 AM
OBS pedal mod stroker_baldy 1994-2003 7.3L Power Stroke 4 04-27-2007 05:10 PM
Cruise control not releasing until I push brake pedal REALLY HARD imported_Arkapigdiesel 2003-2007 6.0L Power Stroke 23 05-30-2006 03:35 AM
