Electrical problem? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Chevy Tech, this thread has received 4 replies and been viewed 678 times.
post #1 of 5 (permalink) Old 11-24-2009, 07:11 PM Thread Starter
Electrical problem?
For the past month now, after starting my truck cold, I have noticed that the lights dim for a couple seconds and then return to normal brightness. This pattern continues for about 5 minutes and then goes away. When the lights dim, you can hear the engine is being loaded as if the A/C compressor is cycleing but it is not. It has new 750CCA batteries and a new alternator. Any ideas? Thanks.
Chevy Tech is offline
post #2 of 5 (permalink) Old 11-24-2009, 07:29 PM Thread Starter
Sorry that I didn't have a sig. It's a '01 Ram Diesel with the six speed manual. Could this be the Intake air heater cycling after cold start? Would they draw enough current at idle to dim the lights for awhile?
1997 Ford F-250HD Super cab/Short bed 4x4
7.3L Power Stroke Diesel
5-speed manual transmission
(Dad's Truck)
2001 Dodge Ram 2500HD 2WD
Standard Cab/Long Bed
SLT Laramie
5.9L Cummins 24Valve Turbo Diesel (Vin code-7)
NV5600 6-Speed Manual Trans.
post #3 of 5 (permalink) Old 11-24-2009, 07:51 PM
TDG Mafia
Jeffybuilt's Avatar
You are exactly right. The intake heater pulls a lot of juice, and the dimming of lights you are talking about is totally normal. When I was new to the Cummins a few years back, I had the same question.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #4 of 5 (permalink) Old 11-25-2009, 12:31 AM Thread Starter
Okay, thank you, I'm glad that it is a normal characteristic of a diesel.
(Dad's Truck)
SLT Laramie
post #5 of 5 (permalink) Old 11-25-2009, 02:29 PM
2nd Gen Guru
Mopar1973Man's Avatar
You got to remember the grid heaters draw 190 AMPs but the alternator only produces 120 AMPs so it a losing battle with the charging system.
When I'm running 3 cylinder high idle it will pull so hard that when the ECM throttles up to keep the steady RPM's it will blow a small cloud of black smoke. Yea the load is that big!
Mopar1973Man is offline
electrical problem, need help Woody303 1994-2003 7.3L Power Stroke 18 08-11-2009 11:12 PM
2006 electrical problem. Rcannon 2003-2007 6.0L Power Stroke 1 05-13-2009 03:58 PM
2005 F-250 Electrical Problem 8upwitHDs 2003-2007 6.0L Power Stroke 6 11-05-2007 06:28 AM
Electrical problem moparcummin General Dodge Discussion 1 03-28-2007 03:43 AM
