01 towing mirrors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rollincoal97, this thread has received 5 replies and been viewed 786 times.
post #1 of 6 (permalink) Old 11-25-2009, 02:19 PM Thread Starter
rollincoal97's Avatar
01 towing mirrors
So i just sold my 96 powerstroke and lookin at getting a 2001 cummins quad cab long box.It has the smaller mirrors on it and i was just wondering how much work is it to put the bigger towing mirrors on it.Are the hookups anywhere close to the same or is some sort or body work needed?
2001 dodge cummins 24v automatic daily driver, quad cab long box, sport/slt package, AFE stage 2 intake, stock exhaust straight piped, EDGE Comp box, fass fuel pump, plugged wastegate, 33x12.5x17 PRO COMP tires and rims
rollincoal97 is offline
post #2 of 6 (permalink) Old 11-25-2009, 02:26 PM
No its pretty easy. You just have to pop the door panels off and unthread some nuts put in the new mirror and reverse the process. Pretty simple. If you get the new mirrors make sure to get the bracket for the big ones.
#23 B.O.M.B. Squad[/B]
rwhite is offline
post #3 of 6 (permalink) Old 11-25-2009, 02:33 PM Thread Starter
I havent seen the truck yet n dont know off the top of my head,but if it has power mirros,are those hookups also the same or dont they even have power mirrors?
post #4 of 6 (permalink) Old 11-27-2009, 03:12 PM
bmoeller's Avatar
At the time the truck was built, electric/heat wasn't available from the factory with the towing mirrors. Required buying 3rd gen mirrors and converting the bases. They are available from aftermarket sellers now. If you have power/heat, you won't lose it. If you want to add power/heat, you could. You'll have to source the switches and wire it yourself, but no biggie.
I just bought a set of these- http://app.infopia.com/Shop/Control/...id/0/SFV/32759
As mentioned, you will need the stiffener brackets for the towing mirrors. Not sure if these will come with them or not, so we'll see.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 6 (permalink) Old 11-27-2009, 03:36 PM
TDG Mafia
Jeffybuilt's Avatar
The above guys comments are right on. I also swapped mine out, and it took less than an hour to do both sides. Very simple and straight forward. There are many vendors who sell them, and the Kool-View brand seems to be the most popular, if not the only one. Shop around a bit, as you will find lower prices if you look hard enough. I sure did.
Good luck.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #6 of 6 (permalink) Old 11-27-2009, 03:54 PM
Official TDG Doctor
hccumminssmoke's Avatar
i did the Kool-Vue's cost less then 200$ and 30 for the bracket...I like em right well...its nice not to loose the power/heat...
Nate
hccumminssmoke is offline
towing mirrors PSD7.3 1994-2003 7.3L Power Stroke 2 04-26-2009 03:08 AM
Towing mirrors Jetmech Whats Been Sold 5 12-31-2008 09:42 AM
07-08 towing mirrors 02bigstrokin Whats Been Sold 3 12-17-2007 10:39 AM
towing mirrors 05dury 5.9L Cummins 12 Valve (1994-1998.5) 9 10-28-2007 03:27 AM
towing mirrors quinton 5.9L Cummins 12 Valve (1994-1998.5) 6 10-25-2007 11:51 PM
