'94-'02 automatics - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Chevy Tech, this thread has received 2 replies and been viewed 1552 times.
post #1 of 3 (permalink) Old 11-29-2009, 05:49 PM Thread Starter
'94-'02 automatics
How are the Dodge automatic transmissions that came in the '94-'02 Cummins? I'm looking to find a Cummins, prefearably a '98.5+ 24valve/manual, but if I find an automatic equipped truck I want to know how they are. The truck will mainly be used as a daily driver and occasionally pull 2-3 atv's but nothing heavier than that. The truck will probably get exhaust right away with possibility for more mods down the road.
1997 Ford F-250HD Super cab/Short bed 4x4
7.3L Power Stroke Diesel
5-speed manual transmission
(Dad's Truck)
2001 Dodge Ram 2500HD 2WD
Standard Cab/Long Bed
SLT Laramie
5.9L Cummins 24Valve Turbo Diesel (Vin code-7)
NV5600 6-Speed Manual Trans.
Chevy Tech is offline
post #2 of 3 (permalink) Old 11-29-2009, 07:03 PM
TDG Mafia
Jeffybuilt's Avatar
The more mods the quicker it will die...
Some hold on quite a while and just act really odd, while others simply give up earlier.
It's all in how it was cared for, and how it was/will be driven. If you plan on putting more power to the motor, spend a bit on the trans, that will help it live another day; until it goes, and needs a full rebuild anyway.
Short term, your probably just fine. My recommendation however, would to be start a small savings account, that when the trans does go, you are ready for it right away.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 3 (permalink) Old 11-30-2009, 02:40 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
Allison Automatics :SOLD: Dualie Medium and Heavy Duty 7 07-09-2007 12:07 AM
