got a ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgetheonlytrk, this thread has received 7 replies and been viewed 560 times.
post #1 of 8 (permalink) Old 12-01-2009, 12:36 AM Thread Starter
got a ?
y on some dodge's u can pull the key out while it run.couple of my buddies can but i cant
dodgetheonlytrk is offline
post #2 of 8 (permalink) Old 12-01-2009, 04:09 PM
Singles Club #2
smokndiesel7588's Avatar
i believe that is because the key is well worn and can be pulled out...i used to be able to do it with just one of my keys for my 93 ford...but i couldnt with the other key
Greg
smokndiesel7588 is offline
post #3 of 8 (permalink) Old 12-01-2009, 07:22 PM
yea on my 01 the key falls out sometimes
but the 97 is locke din when you turn it on
the 01 has 180k the 97, 250k
97 5.9
97 7.3
01 5.9
08 6.4
12vcope is offline
post #4 of 8 (permalink) Old 12-01-2009, 09:23 PM
You know those guys also might be running turbo timers . Mine stays running until EGT's hit 320 sometimes takes a while.
RckMtnthunder is offline
post #5 of 8 (permalink) Old 12-01-2009, 10:49 PM Thread Starter
no they dont i have the edge with attiude and i can do it that way but cant do it while its just running
post #6 of 8 (permalink) Old 12-02-2009, 12:51 AM
i have a 97 & the key is tight in the ignition. on my dad's 99 it will slip right out & it has about 100k fewer miles than the 97. maybe when they screwed up & went to the vp pump, they decided to screw up the ignition switch too.
kwswan is offline
post #7 of 8 (permalink) Old 12-02-2009, 12:57 AM
I haven't actually seen this on a dodge before. My brother's old ford, his current ford, and my dad's ford all do it though. In fact, theirs are so worn, that you can just turn the ignition without the key and start the truck.
My 2000 dodge has no issues with this one at all. Neither did my 95. I didn't know it was a common problem.
post #8 of 8 (permalink) Old 12-02-2009, 03:02 AM
bmoeller's Avatar
My old Mazda B2000 was one that I could use ANY key that would slide in the key hole to start it.
"Obama = Hoax and Chains"
bmoeller is offline
