Fuel pressure guage - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Chevy Tech, this thread has received 8 replies and been viewed 7509 times.
post #1 of 9 (permalink) Old 12-04-2009, 12:29 AM Thread Starter
Fuel pressure guage
On the truck in my sig, my dad's truck, we are discussing the addition of a fuel pressure guage. We are aware of the potential that the lift pump could fail and cause damage to the injection pump so a fuel pressure guage is on the agenda. My question is how does the fuel pressure guage tap in or attach to the fuel system? Thanks.
1997 Ford F-250HD Super cab/Short bed 4x4
7.3L Power Stroke Diesel
5-speed manual transmission
(Dad's Truck)
2001 Dodge Ram 2500HD 2WD
Standard Cab/Long Bed
SLT Laramie
5.9L Cummins 24Valve Turbo Diesel (Vin code-7)
NV5600 6-Speed Manual Trans.
Chevy Tech is offline
post #2 of 9 (permalink) Old 12-04-2009, 01:06 AM
TDG Mafia
Jeffybuilt's Avatar
Straight from Geno's Garage site..http://www.genosgarage.com/departments.asp?dept=92
The need to monitor the fuel pressure from the fuel transfer pump to the Bosch VP44 injection pump is CRITICAL. You should do this with a gauge. We suggest that you not use a pressure light. The light illuminates when the problem has gone too far. With the gauge you can watch fuel pressure trends. Gauges range from $99 (Westach, electronic) to $130 (ISSPRO mechanical) - What I have on my truck...Love it. to $225 (Auto Meter, electronic).
Here is a link to the "big line" filter to VP44 fuel line. It has a spot for a 1/8 in NPT to be attached (TO your isolator; than TO the gauge line itself) This is what I have and it is a very easy way to go, as well as cutting down on restrictive flow. If you have any super specific fuel system questions, feel free to PM me, and I will help out as much as possible. Also I would be happy to send some pictures of my set up, and explain how it works/is set up if you need.
Regardless of your gauge choice, you have to tap into the fuel system. On ‘98.5-’99 trucks you can remove a 1/8 NPT fitting on top of the fuel filter assembly and attach fuel hose or pressure sending unit on top of the assembly. On ‘00-‘02 trucks, the filter design is different. So, we offer a Universal Fit Fuel Pressure Line (Vulcan-FH) that has a female adapter that screws directly into the Schrader valve test port that is located at the Bosch VP44 fuel pump. We offer several other ways to access fuel pressure for ‘98.5-‘02 trucks (banjo bolts, filter caps). We also offer several fuel pressure gauges that you can use to test the truck’s fuel system.
I run the Vulcan Big Line filter to VP line, which has a port for hooking up line to your isolator. It is very simple. Here is the link to that...http://www.genosgarage.com/prodinfo....er=VULCAN_VP02
The install is very easy. I would recommend using this, and at the same time, do your isolator and gauge install.
Here are the Gauge and Isolator, sold through Geno's togeather in a kit...same as I use: http://www.genosgarage.com/prodinfo....ber=ISS-R5604R
And here is the mount I used for my FP gauge: http://www.genosgarage.com/prodinfo....er=GM-DG-15012
As you can tell, I am a fan of Geno's Garage, and when I was getting these pages togeather for you, I saw this on thier site.....
Buy 1 gauge, get SINGLE or DUAL mount at 50% off
So this would put you at about $130 for the gauge and isolator, and with 50% off the mount...$15, so $145, and $50 for the Vulcan line...so thats $195...not bad for a quality set up.
Hope this helps.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 9 (permalink) Old 12-04-2009, 04:16 PM
anybody ever use an electric guage instead of the mechanical one? i know they are a little higher in price,but you don't have to run the fuel line into the cab. just looking at the different options. we have a 99 that the ip is going to have to be replaced on & looking at the options available.thanks
kwswan is offline
post #4 of 9 (permalink) Old 12-04-2009, 06:49 PM
looks like you need a programer get the edge juice w/attitude moniter you can moniter fuel press, egt,boost, and ten other componets, mot to mention the shift on the fly 5 level settings giving you up to a 120 extra ponies and 350 ft pounds of tourqe and xdp has them on sale for $619.20
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #5 of 9 (permalink) Old 12-04-2009, 07:46 PM
it's gonna cost me $1500 for a new lift pump & inj. pump.,just looking for the best cheapest way to monitor the fuel pressure. a man told me one time that poor folks have to do things poor folk ways. plus im not looking for any extra hp, it does good like it is for what it is used for.
kwswan is offline
post #6 of 9 (permalink) Old 12-06-2009, 01:57 AM
bmoeller's Avatar
The Edge Attitude monitor can be used as a stand alone unit. No need to run a fueling box to make it work. Plus, it monitors FAR more than just 2 or 3 things. Virtually no wiring either. All plug and play.
"Obama = Hoax and Chains"
bmoeller is offline
post #7 of 9 (permalink) Old 12-11-2009, 07:37 PM
Supporting Vendor
As with all gauge manufacturers, we recommend using an isolator if you are running a mechanical fuel pressure gauge. By the time you add the cost of the isolator, you are equal to the cost of an ISSPRO EV2 electronic gauge. The installation is much simpler as well.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 271k miles
10 ISSPRO Prototype Performax™ gauges in Pillar & Overhead pods & sitting on dash, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps, Swamps tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
32' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
2000 VW Jetta TDI - Kerma tune, Der Chimera Stage II Clutch
NRA member and certified firearms instructor, GOA Life member, IDPA member
Michael is offline
post #8 of 9 (permalink) Old 12-11-2009, 08:13 PM
Regards,
Michael Pliska
thanks for the reply. i was wanting to go the electronic way because of the easier install. can you get me a price for a fuel pressure gauge setup on a 99 24v. thanks stevie
kwswan is offline
post #9 of 9 (permalink) Old 12-14-2009, 07:48 PM
Supporting Vendor
Sorry, but we don't sell the EV2 or Performax series direct from the factory (we let our dealers have first crack at the newest products). Please PM one of our dealers for a quote. Here is a quick list of dealers who are TDG sponsors (and if I missed anyone, please let me know):
8LugTruckGear.com - Skyd Ram George
ATS Diesel Performance - Eric @ ATS
Dfuser Performance Products - Dfuser
Diesel Performance Parts Inc -
GOS Performance - GOS
KT Performance - KT Performance
Regards,
Michael Pliska
Michael is offline
The Following User Says Thank You to Michael For this addition to TDG:
kwswan (12-14-2009)
Fuel Pressure Guage Brand-Xrugger 5.9L Cummins (1998.5-2002) 3 05-21-2009 03:39 PM
fuel pressure guage set 95turbo12v 5.9L Cummins 12 Valve (1994-1998.5) 4 05-05-2009 03:37 PM
Fuel pressure guage and pod birddog55 Supporting Vendors Forum 1 04-22-2009 05:35 AM
12v Fuel pressure guage DalmationDodge 5.9L Cummins 12 Valve (1994-1998.5) 0 08-14-2006 01:52 AM
Fuel pressure guage question rrworker 5.9L Cummins 12 Valve (1994-1998.5) 3 06-06-2006 11:55 PM
