CAD working Backwards?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Copper, this thread has received 7 replies and been viewed 1388 times.
post #1 of 8 (permalink) Old 12-07-2009, 07:06 AM Thread Starter
This is a strange one - I dropped my pickup off at a local shop a week ago to get the tranny flushed. While they were down there, they changed one line with a pinhole, and a power steering hose that was weeping. When I picked it up Friday after work, I noticed a rumble, and the "FWD" light was on, in 2-hi. So I stopped, and shifted it to 4-hi - and the light went out! I could spin the back wheels, so it definitely wasn't in 4. I can go back to 2-hi, and the transfer case shifts out, but the 4wd light comes on and the axle locks back up (you can feel it on the road)!! So I went to 4-lo, and sure enough, the light goes OUT and it's in 2wd.
So - The question is - what did they unhook and hook back up backwards?? I'd like to take it back to the guy and tell him to figure it out himself, but it snowed here this weekend, and I'm not sure I can get it back to the shop in 2wd......
Copper is offline
post #2 of 8 (permalink) Old 12-07-2009, 07:38 PM
Ghost
Phily's Avatar
I diffedently wouldn't be driving a Cummins around in snow with only 2wd. It sucks, I know. Who knows what the guy could have done. You still clearly have a issue w/ vaccum, but that's not saying it's your only issue. However. There is a easy rememdy for this to make sure it never happens again.
CAD DELETE.
Consider the following:
A. If you got 30 spline axle shafts which were found in many 98's and some 99's. You can get by w/ just replacing the long shaft w/ a upgraded chrom moly shaft. EMS sells this @ Ebay for $335.00
B. If you got a 00-02. You can hunt down a 32 Spline big shaft from a 2002, kind of hard to come by, however the ones I have come have only ran $50.00
C. Upgrade to 35 Splines (And locate a carrier). Chrom Moly 35 shafts run 585$. EMS gots this covered again for the 94-99 model years, while Dynotrac gots the 00-02 model years covered. Both exactly $585 which is a steal if you compare to other Dana 60 chrom moly shaft kits.
"C" can be taken a step farther if you want to convert your unit bearings to lock outs. But then you are getting over $2,000.
D. Lock your shift fork in the locked position or find a way to manually control it via cable or electric.
My theory on the matter is: You bought a 4x4, it's time to make it reliable. The CAD is without a doubt, the biggest cause of 4x4 malufunction in these. OEM fixes just repair vacuum lines, which in time will always root.
Phily is offline
post #3 of 8 (permalink) Old 12-07-2009, 07:43 PM
Ghost
Phily's Avatar
On a side note, I also recommend going to a LSD* or Locker** for the front carrier. These things do horrible offroad. Stiff, with most of the weight in the front end.
*True Trac is the only carrier I'd do up front. Any other LSD is going to loose the transparent feel.
**I would only do a selectable up front unless lock outs apply.
Phily is offline
post #4 of 8 (permalink) Old 12-12-2009, 12:56 PM
bmoeller's Avatar
I wonder if the vacuum hoses got put back on the wrong fittings. That would cause problems if they are installed correctly.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 8 (permalink) Old 12-18-2009, 02:48 AM Thread Starter
D'oh! Flipped the vacuum lines back to correct where they go from the axle to the frame where they "helped" me and replaced them, all's good now. I'm used to bowtie frontend problems (even though I haven't owned one for years), I forgot these were vacuum both ways, I was thinking vacuum/spring, more like the actuator/spring Chevys.
Copper is offline
post #6 of 8 (permalink) Old 12-19-2009, 07:54 PM
Ghost
Phily's Avatar
GM's front end problem include CAD problems, not to mention shafts and housing. . Unless you are talking about the K series trucks.
Phily is offline
post #7 of 8 (permalink) Old 12-21-2009, 08:04 AM
bmoeller's Avatar
More specifically the TLA.
bmoeller is offline
post #8 of 8 (permalink) Old 12-23-2009, 02:44 PM
2nd Gen Guru
Mopar1973Man's Avatar
That was my thought on this... Vacuum line were hooked backwards...
Mopar1973Man is offline
Backwards Silencer Ring?? Cummins_Beast 5.9L Cummins (2003-2007.5) 11 01-07-2010 10:42 PM
changed engine not charging mpg backwards rxpower 5.9L Cummins (1998.5-2002) 5 11-25-2009 02:31 PM
backwards brake lights? bseals Medium and Heavy Duty 1 08-15-2009 08:34 PM
Cummins ran backwards??!! BigRed Cummins 5.9L Cummins 12 Valve (1994-1998.5) 11 06-04-2009 03:50 PM
Pulling 5th Wheel...Backwards????? bigdraft Towing and Hauling 72 03-23-2008 01:28 PM
