Hard to start when cold. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by veritas42, this thread has received 6 replies and been viewed 7214 times.
post #1 of 7 (permalink) Old 12-07-2009, 04:06 PM Thread Starter
Ok so recently have had a cold spell here in WA, about 20-30 degrees. Went to start truck this morning and took about 5 min, I cycled pre heater every time when it finally started it ran real rough for about 30sec to 1 min. After that no issues. Now I am guessing it is probably the obvious JUST THE COLD. Granted I also did not plug her in cus I have never had these issues before. However I have never ran the truck in this cold of weather, since installing my air dog 100. Some further info when it ran rough was smoking alot etc till it warmed up a bit. After about 1 min of running shut off and it fired right up. No codes using the key trick. Also further info, I have a fairly new IP from Industrial I installed this summer, Air Dog 100 lp, and a fuel gauge set up just like moparmans at the ip for the pressure. During start and run fp was at 13-15, the entire time. Also I have not winterized my fuel at all yet. So go ahead and let me know what ya think and suggestions, also I think I have an air leak at the manifold from where I took off the old fuel filter, or maybe one at the sending unit from the air dog. I am winterizing fuel today and plugging in tonight, but I cant plug in at work and had starting issues at work yesterday (High temp of 31), it only took 3 tries yesterday at work though. Allright thanks for your help.
01 2500, quad cab, 2wd, auto, 132k, turbo rebuilt good as new by htt , and 0216 code for 1 1/2 years now. Airdog 100 fuel system after 3 stock lift pumps.
veritas42 is offline
post #2 of 7 (permalink) Old 12-07-2009, 06:35 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
Hi I dont think you should need to plug it in. I never have plugged mine in since new and fires up fine in -0. Although I would recommend running the fuel back threw the stock filter housing because there is a heater in there just dont put the filter itself back in the housing. Or your intake heater is not working right good luck
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #3 of 7 (permalink) Old 12-09-2009, 04:19 AM Thread Starter
Cool ya I just winterized the fuel, we usually don't get this cold of temps. I plugged her in last night and she fired right up without skipping a beat. Leaving work were I can't plug in is another issue entirely, but not nearly as bad as in the morning without plugging in. I think I might eventually put an inline heater rather than use the old fuel filter canister. What do you think about using the old fuel filter canister MoparMan?
post #4 of 7 (permalink) Old 12-09-2009, 06:34 AM
Are you absolutely sure your grid heater is working? I know that mine will start without the grid hooked up down to about 40 degrees and you can't tell the difference (long story ). I'm betting yours is starting off compression heat only, if it's cackling and grumbling about it at 20 above.
Copper is offline
post #5 of 7 (permalink) Old 12-09-2009, 06:05 PM
When it is cold, you do not want to just keep cranking and cycling the grid heater on and off, you can overheat the grid heater, and the starter. I lived in the north for a long time, the best way to start a diesel, without either, and you really can damage an engine severely with either, is to cycle the start aid, then crank for 15 seconds if it does not start, wait for 1 minute, and do it again. If you keep cranking the fuel that is injected just cools the cylinder down, waiting allows the fuel to warm in the cylinder and fire when you crank it the second time. It does work, If it is below freezing, and you have the ability, plug it in, even for a short time, it helps and I leave mine plugged in after it starts till I leave, Never longer than 1 minute.
Johnp3 is offline
post #6 of 7 (permalink) Old 12-10-2009, 11:15 PM
You should no have to plug in a t 20-30 degrees, must be somthing else, was it a slow crank? How are your batts? I dont plug mine in unless its below 5 and then i plug it in for a bout a hour never had any issues yet.
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #7 of 7 (permalink) Old 12-12-2009, 04:03 PM Thread Starter
Ya I wasn't just cranking, I am well aware of the intervals for cranking on the engine and what it can do to the starter. Ya I just plug it in now no issues fires up instantly.
Ya there is no issue with the truck, I figured thanks to yall enlightening me that it was due to their being no inline fuel heater anymore, due to airdog. Also maybe I should have clarified better but temps were single digit in the mornings. Also I already checked my grid heater, first thing, it was working as it should. Thanks for the replies guys. I guess I went into panic mode for a sec thinking the excessive smoke and rough idle was a vp44 issue, cus that is what had happened when the vp died before.
Is my icp bad hard start cold Stroker99 1994-2003 7.3L Power Stroke 1 10-08-2009 02:39 AM
hard to start cold? daturbosix 2003-2007 6.0L Power Stroke 20 12-08-2007 03:19 PM
Hard start after cold night? Beer Mod 1994-2003 7.3L Power Stroke 17 10-16-2007 06:30 AM
Hard cold start problems lowridin70 6.5L Diesel Engine 10 04-09-2007 01:37 PM
Hard Start When Cold tcl2665 1994-2003 7.3L Power Stroke 2 02-13-2007 01:34 PM
