Found my noise and air leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by veritas42, this thread has received 8 replies and been viewed 1811 times.
post #1 of 9 (permalink) Old 12-08-2009, 05:04 AM Thread Starter
Well part of the gasket is missing where I took off the old fuel filter canister when I put on the air dog. It is about as long as the distance between both bolts. Anybody know what that gasket is called and where I can get it? It is the gasket that seals I believe the manifold under the injection lines and pre heater. I sealed it down with the bolt and washer set up the best I could but it is still pushing air. At least I cant hear it in the cab anymore. Will it hurt driving it since it is pushing air and not sucking it? Other than the power loss.
01 2500, quad cab, 2wd, auto, 132k, turbo rebuilt good as new by htt , and 0216 code for 1 1/2 years now. Airdog 100 fuel system after 3 stock lift pumps.
veritas42 is offline
post #2 of 9 (permalink) Old 12-09-2009, 01:32 AM
bmoeller's Avatar
No boost at an idle. Go to Cummins and do it right. VERY cheap insurance. A dusted engine is a VERY bad thing.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 9 (permalink) Old 12-09-2009, 04:15 AM Thread Starter
I am kind of confused by what you mean. It is a simple gasket replacement. A leak like that though, will basically give me no boost at idle though?
post #4 of 9 (permalink) Old 12-10-2009, 02:47 AM
bmoeller's Avatar
Unless you install a VG turbo, there is never any boost at idle.
bmoeller is offline
post #5 of 9 (permalink) Old 12-12-2009, 04:09 PM Thread Starter
Ya which is why I was wondering why you said]No boost at idle, hmm what were you talking about?
post #6 of 9 (permalink) Old 12-12-2009, 05:02 PM
If the gasket is blown out, Get it fixed it is not a big thing or do it your self, get it clean, and while you are at it, do the valve set. If you tighten the bolts you can distort the cover, you want to file the cover flat when it is off. And if you leave it you will dust the motor, at Idle they do draw a vacuum, and when you first step on the throttle also. You will need two intake horn gaskets , and the intake gasket. if you do the set you will need the seals for the hold down bolts take your CPL when you order parts. the torque is 18 lbs
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
veritas42 (12-12-2009)
post #7 of 9 (permalink) Old 12-12-2009, 06:24 PM Thread Starter
Thanks alot, ya I misplaced my manual so I couldn't think of the name of were the gasket was. By dust the motor I assume you mean blow it up? Or just destroy it? Basically one and the same. Also it has been making this noise since early summer and I couldnt find the noise. I took it to a diesel shop and they couldnt find it either. I didn't see it until I guess part of the gasket disengrated. Ahhh... I should have checked their anyways. So basically what damage might I have done? And should I stop driving it right away, which would kind of put me in a bind. Or just go ahead order it and, replace when I get it.
post #8 of 9 (permalink) Old 12-12-2009, 06:55 PM
You can only fix it when you can and clean out the intake, what is done is done, dirt is a very bad thing in a diesel. Play safe!
Johnp3 is offline
post #9 of 9 (permalink) Old 12-12-2009, 07:33 PM Thread Starter
Haha, I thought Diesels loved dirt? Hopefully I will be ok, cus feeling it the air was pushing out rather than causing a vacuum effect (at least seemed to be). I put a piece of ceram wrap against where the gasket was missing and it pushed it out rather than sucking it. I ordered the intake gasket from auto zone, and got my other gaskets from Geno's. Thanks for the help.
Injector noise / slight oil leak slickricks7.3 1994-2003 7.3L Power Stroke 5 03-31-2008 03:10 AM
Injector Noise/ Slight oil leak slickricks7.3 1994-2003 7.3L Chips & Tuners Forum 1 03-27-2008 11:31 PM
Found my boost leak... Foxx 1994-2003 7.3L Power Stroke 2 10-10-2007 11:06 PM
Fuel Leak and Hissing noise??????? brooks321 1994-2003 7.3L Power Stroke 3 12-08-2006 10:26 PM
Oil Leak Found! Trbotime 2003-2007 6.0L Power Stroke 10 06-18-2006 10:07 PM
