I think I know the answer, still would appreciate advice. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Canyon JYD, this thread has received 2 replies and been viewed 636 times.
post #1 of 3 (permalink) Old 12-09-2009, 04:08 AM Thread Starter
Formerly NATTYGASMECH
Canyon JYD's Avatar
Water in fuel light on. Ok heres the story. Went romping in the snow through some deep stuff last night. While driving through the pretty much white out and close to 2 ft of drift, the water in fuel light came on. I have installed a FASS 150/150 and run 1/2 in line from FASS to IP. Eliminated factory fuel bowl, lines, etc. The factory connectors are just loose in the engine compartment. Since they are factory connectors I did not tape the crap out of them like I would something that would easily ground out. Does anybody think snow could have cause the light to come on or do you think I will see this again. This is the first time I have seen this. I did only do the install the beginning of last year. This is the first time I have gone rompin in a white out. Also When I stopped for a while and let the truck idle while I went and checked some stuff out, when I came back the light was off. After rompin again it came back on. I think I have the answer, but if anyone on here has seen this related to wiring or grounding issues please let me know.
(Quote: M123KT-450) "That's what happens man it's hard to Damage steal with tin foil ! "
Canyon JYD is offline
post #2 of 3 (permalink) Old 12-09-2009, 04:11 PM
Singles Club #2
smokndiesel7588's Avatar
I have had something similar occur to me...I had the Fass 150/150 installed while on vacation and had all the stock fuel stuff removed. They left the connectors just hanging in the engine compartment and whenever i do any driving through any water puddles that send water up that direction it turns my water in fuel light on.
Greg
smokndiesel7588 is offline
The Following User Says Thank You to smokndiesel7588 For this addition to TDG:
Canyon JYD (12-10-2009)
post #3 of 3 (permalink) Old 12-10-2009, 12:12 AM Thread Starter
Canyon JYD's Avatar
It's good to hear that someone else has had the same thing happen. Guess I'll go under there and tape em up.
Answer me this. jdydiesel 2008-2010 6.4L Power Stroke 8 08-29-2009 05:33 PM
Pot is the answer...LOL danster The Parking Lot 89 02-28-2009 04:19 AM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 10:08 PM
looking for an answer jwb3154 5.9L Cummins (1998.5-2002) 4 01-20-2007 03:17 AM
Anyone have an answer? diesel379 1994-2003 7.3L Power Stroke 2 09-30-2006 07:48 AM
