Moving to Iowa from Maryland - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bpul2113, this thread has received 3 replies and been viewed 643 times.
post #1 of 4 (permalink) Old 12-11-2009, 02:56 AM Thread Starter
it is much colder in iowa i believe, what should i do besides plugging it in
it is completely stock 5 spd manual except for a bhaf filiter any hints or suggestions
also should i put some kinda cover on the front of my truck in winter
bpul2113 is offline
post #2 of 4 (permalink) Old 12-11-2009, 12:21 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
you will be fine just run it as you have, make sure you have good fuel,grid heater is working,fuel heater is working and filter is fresh.and use anti gel treat and you should be good
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #3 of 4 (permalink) Old 12-11-2009, 12:40 PM
4cstr's Avatar
Images: 35
whereto in Iowa are you going?
~Dave~
4cstr is offline
post #4 of 4 (permalink) Old 12-12-2009, 12:42 AM
bmoeller's Avatar
"Obama = Hoax and Chains"
bmoeller is offline
Maryland International Raceway, Mechanicsville Maryland, August 8th NHRDA Events and Gatherings 1 08-04-2009 08:46 PM
Hello from Iowa Redneck10 Introductions 16 03-02-2009 03:23 PM
Hello to everybody from Iowa BBdiesel Introductions 14 11-03-2007 12:44 PM
Hello from Iowa S&Dqtrhrs Introductions 12 06-07-2007 12:26 AM
another Iowa boy here!! imported_Doodah 5.9L Cummins 12 Valve (1994-1998.5) 8 01-18-2006 06:46 PM
