2001 RAM2500 steering issues ! ?'s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 41 replies and been viewed 12849 times.
post #1 of 42 (permalink) Old 12-15-2009, 10:04 PM Thread Starter
M123KT-450's Avatar
Truck seems to wander around as tho the steering is loose n worn, yet Most of everything has been replaced and adjusted . . .
Parts replaced:
1. steering box.
2. all 4 tie rods.
3. steering stablizer.
4. Intermediate shaft.
Truck was put on the rack right after installing all the above parts.
The truck has improved greatly but is still wandering around, and when making lane changes and slow moving turns seems to have excessive body roll.
Any thought's ? where to go from here ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 42 (permalink) Old 12-15-2009, 11:32 PM
cowboytw13's Avatar
Did you just put new tires on? Every time I have put new tires on I have the exact same problem. It goes away after a week or two once the tires get "broke in"
cowboytw13 is offline
post #3 of 42 (permalink) Old 12-16-2009, 12:09 AM Thread Starter
M123KT-450's Avatar
Yes there was a new set of tires installed on it ! 265/75R16E MTR's . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #4 of 42 (permalink) Old 12-16-2009, 03:46 AM
learnin' as I go...
killsme's Avatar
track bar/bushings!
'13 Ram 2500 4x4 club cab
killsme is offline
post #5 of 42 (permalink) Old 12-16-2009, 02:03 PM
bmoeller's Avatar
Ya, was the track bar replaced? Don't bother with the OEM part. Mine wore out after less than 10k miles. Convert it to the 3rd gen track bar. Costs a little more to do it, but worth every penny. http://www.sourceautomotive.biz/shop...4x4-50-20.html
http://www.sourceautomotive.biz/shop...Bar-55-20.html OR http://www.sourceautomotive.biz/shop...Bar-56-20.html
And add a steering stabilizer. Will drive better than new. Gets rid of the slop from the bushing in the steering box. http://www.sourceautomotive.biz/shop...4x4-50-20.html
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 42 (permalink) Old 12-16-2009, 02:41 PM
I doubt I can add much to this especially when I see your list of machines. My 2002 seems to follow the lean in the road and the crown more than other cars and trucks I have owned. Some of this IMHO is due to the solid axle in the front end? You can also get a slight pull when you get on and off the gas if the alignment between front and rear wheels is not perfect. It sounds like you have done multiple alignments so I guess thats not it? I know a truck with independent front suspension takes less attention to drive; but I would not want to give up my Dodge! Let us know if you work it out, then we will all learn something.
road runner is offline
post #7 of 42 (permalink) Old 12-16-2009, 04:01 PM Thread Starter
M123KT-450's Avatar
Thanks for all the help and suggestion's . . . I will start adding some more parts, how many bloody times dose a truck need to go on the rack ?
This the only heap that don't drive straight, rest of my Relics i can let go of the wheel and it'll continue to roll straight . . .
anywho thank's guy's i'll some more part adding and reracking and see what we get . ..
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #8 of 42 (permalink) Old 12-16-2009, 04:44 PM
Official TDG Doctor
hccumminssmoke's Avatar
bj's?
Nate
hccumminssmoke is offline
post #9 of 42 (permalink) Old 12-21-2009, 08:12 AM
bmoeller's Avatar
Tires are a factor at times. I've noticed wider tires tend to be worse about following the grooves in the roads from big trucks. And, IFS trucks will do the same thing.
You can also get a slight pull when you get on and off the gas if the alignment between front and rear wheels is not perfect. It sounds like you have done multiple alignments so I guess thats not it? [/QUOTE]
I wonder if you have enough toe-in? Sometimes OEM specs aren't good enough.
Are you doing a 4 wheel alignment, or just the front only?
bmoeller is offline
post #10 of 42 (permalink) Old 12-21-2009, 03:11 PM
STROKER SMOKER's Avatar
Believe me bro i know exactly what ur talkin about. I have replaced EVERYTHING in the front end of my 01 cummins. EVERYTHING!!!!!!!!! ball joints, tie rod ends, steering shaft, geer box, geer box stabalizer bracket, track bar, track BAR DROP BRABKET, DUEL STEERING STABALIZERS, alignment ( 2 times ), drop pitman arm, and everything else you can imagin. the sad thing is i am prob goin to sell my truck in the very near future and get a mustang saleen do to this problem which really sucks but its to the point now i hate driving the truck cause its such a pain in the *** to keep it in one lane its so bad ive got an 87 reg cab long bed chevrolet on 44's and i have been driving that almost every day for the last month cause it drives better then my dodge and im over fightin that thing the whole time im driving it. so if you figure out a solution or anybody else has any other ideas i can try it would be greatly appreciated so maybe i could avoid having to sell my truck.
STROKER SMOKER is offline
2001 Ram2500 Power/Performance Mods. M123KT-450 5.9L Cummins (1998.5-2002) 16 12-15-2009 03:57 AM
Power steering issues jdydiesel 2008-2010 6.4L Power Stroke 12 08-14-2009 05:34 PM
2001 F250 Crossover Steering & Adjustable Track Bar w/ 10" high (8" lift+2" shackles) kcrowe 1994-2003 7.3L Power Stroke 0 07-02-2009 06:37 PM
2001 Steering Sector Leak? razrbakcrzy 5.9L Cummins (1998.5-2002) 1 02-06-2008 10:29 PM
Steering Box Issues powerstroke2003 1994-2003 7.3L Power Stroke 2 10-08-2007 01:32 AM
