2001 5.9 ECU problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pjw, this thread has received 3 replies and been viewed 1583 times.
post #1 of 4 (permalink) Old 12-18-2009, 01:30 PM Thread Starter
pjw
I have a 2001 dodge 3500 dually with a 5.9. Millage 225,000 We are getting ready to put the 4th ECU in it. Any insight on what my be causing the ECU to go?? They last just over a year ?? Very fustrating & expensive !!! The orig. lasted 150,000 miles.
pjw is offline
post #2 of 4 (permalink) Old 12-18-2009, 05:17 PM
I'm not as knowledgeable as most of the guys here about these trucks, but as an IT guy, I can tell you that electronic/computer components pretty much fail for two reasons:
1) Too much heat (out of spec for the part)
2) Bad power (too much/too little/surging/inconsistent)
Barring a secret nuclear test near you that generated an EMP sufficient to cook your chip (kidding), I'd suspect its one or the other of those, or some combination? Check grounds, too. (Had plenty of silly problems with those, myself...)
Anyone who knows these trucks think of anything that could be a cause of those two conditions??
_____________________________________________
'01 Ram 2500 5.9l CTD
MBRP 4" Exhaust / Edge Juice w/ Attitude
AirDog 150 / K&N Intake / TransferFlow 75gal aux.
n0ekt is offline
post #3 of 4 (permalink) Old 12-18-2009, 05:30 PM
The only time I have seen continual ECM failures is when there was a ground problem, the ECM grounds threw any wrought it can. If you are not doing a test of all ECM pins for proper power and grounds you will do it all again. Normally you will be getting a lot of codes.
Johnp3 is offline
post #4 of 4 (permalink) Old 12-18-2009, 06:47 PM Thread Starter
pjw
Thanks for the info. I`ll have the dealer check all the pins for proper power and grounds. I`ll get a list of the codes as well to share. Any thoughts on the alt. throwing out some weird readings??
pjw is offline
2001 International 4700 Bucket T444 engine ignition problem Braelecorp Medium and Heavy Duty 1 05-23-2009 04:34 AM
2001 F 250 4WD automatic tranny problem (overdrive) Shorty Bang 1994-2003 7.3L Power Stroke 1 11-03-2007 01:51 AM
2001 npr trans problem burkeftm Medium and Heavy Duty 1 06-14-2007 10:04 PM
1 new problem, 1 old problem, 1 problem fixed LOL Liftedpsd 2003-2007 6.0L Power Stroke 16 04-23-2007 12:13 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
