Extended crank before firing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by STROKER SMOKER, this thread has received 5 replies and been viewed 7384 times.
post #1 of 6 (permalink) Old 12-18-2009, 10:05 PM Thread Starter
STROKER SMOKER's Avatar
Unhappy Extended crank before firing
HEY GUYS QUICK QUESTION. IN THE LAST FEW WEEKS MY TRUCK HAS GOT HARDER ANDHARDER TO START IN THE MORNING OR ANYTIME THE TRUCK SITS FOR MORE THAN 5 OR 6 HOURS. IT TAKES ABOUT 5 TO8 SECONDS OF CRANKING TO FIRE BUT ONCE WARMED UP. LIKE IF I RUN INTO A STORE OR GAS STATION IT FIRES UP RIGHT AWAY WHEN I GET BACK IN THE TRUCK. MY QUESTION IS COULD IT BE THE HEATER GRID GOING BAD OR DO I HAVE A FUEL ISSUE? THANKS
STROKER SMOKER is offline
post #2 of 6 (permalink) Old 12-21-2009, 08:14 AM
bmoeller's Avatar
I'd check for air getting into the lines. Could have a cracked rubber line. They can be cracked and not leak fuel. But, will allow air into the system.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 6 (permalink) Old 12-23-2009, 02:42 PM
2nd Gen Guru
Mopar1973Man's Avatar
I agree it could be a air leak in the system...
Grid heater are only for cold cold weather that all if the block and manifold are above 32*F you really don't need grid heaters. But if there is a small air leak allowing a loss of prime to both the VP44 and the lift pump you could be cranking awhile.
Mopar1973Man is offline
post #4 of 6 (permalink) Old 12-23-2009, 09:09 PM
bmoeller's Avatar
Tell that to my 12v. It prefers 40* and above. THEN, I can forget needing the grids. The '99 will start at ~20* before cycling them once.
bmoeller is offline
post #5 of 6 (permalink) Old 01-13-2010, 02:51 PM
Agreed. Start with looking for a leak in the system. I would still look at putting new relays in, they are cheap. The relays are probably the problem. My 02 did the same thing.
hin0031 is offline
post #6 of 6 (permalink) Old 01-14-2010, 01:15 AM
Dinner's Avatar
My truck did the same thing short while after I purchased it. After checking the fuel system over and over for leaks and swapping Vp44s I still had the hard start issue. Then one day I had the truck running, popped the hood and noticed a really slow drip at cylinder 5 fuel line. Ended up being the cross over tube o-ring had a small nick in it. Changed all 6 at the time and the hard start went away.
2001 Dodge 2500 4X4: Goerend, TST, Smarty, MVP, BD Rad, Injectors, Two Turbo's, Snow Performance, Supporting Mods...
12.7 @ 108mph Aug 2011
Canadian Club Member #14
Dinner is offline
Cyl. 2-3-5-8 firing late. SneakyPete 1994-2003 7.3L Power Stroke 8 05-25-2009 06:55 PM
cylinder not firing? 9512valve 5.9L Cummins 12 Valve (1994-1998.5) 21 04-20-2009 05:23 PM
Extended Crank Issue TurboTPI Duramax 2001-2004 (LB7) 4 04-23-2008 01:31 PM
Only firing on one side? 1996 StrokerKid 1994-2003 7.3L Power Stroke 11 12-31-2007 12:49 AM
firing order edkcmiller 6.5L Diesel Engine 1 07-24-2007 01:26 AM
