Gauge question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeffybuilt, this thread has received 3 replies and been viewed 884 times.
post #1 of 4 (permalink) Old 12-21-2009, 10:07 PM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
Gauge question
My Isspro transmission temp gauge just started acting real odd. Last weekend while on a 1,000 mile trip, about half way through, it just started jumping and going crazy; 160-250-100-270-etc. So after it jumping like this for a short while, maybe 45 minutes, I decided to pull off the hwy. and cut the wires to the probe, which is located in my trans test port.
Well, I did that, and it seemingly stopped jumping for a while, seeing as now it has no power/ground going to it. Well, yesterday on my way home from work, it jumped a few times...and it did it again today.
What is with this thing? I have never had any trouble with this, or any of my Isspro gauges before.
What could be causing this to happen with no power/ground? Or are the 2 wires I cut simply for "sending" the temp signal/ground, and not a power wire...since the real "power" should be coming from where it is spliced into the headlight dimmer switch for the bulb?
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #2 of 4 (permalink) Old 12-22-2009, 01:19 AM
bmoeller's Avatar
If it has an amplifier box, check the screws on the box. They work loose sometimes, til well seated.
"Obama = Hoax and Chains"
bmoeller is offline
Jeffybuilt (12-22-2009)
post #3 of 4 (permalink) Old 12-23-2009, 03:21 AM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
That is exactly what the problem was. The screw holding down the trans temp sending wire had backed off enough to let the wire bounce around causing intermitant power to the gauge. Fixed it today.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #4 of 4 (permalink) Old 12-23-2009, 09:25 PM
bmoeller's Avatar
Good deal. I ran into the same problem with my trans temp gauge. After going through that twice (and checked all of the screw on the box), I haven't have to do it since.
bmoeller is offline
Gauge Question kwmcdani 2003-2007 6.0L Power Stroke 4 05-01-2008 03:58 AM
Gauge question huckleberry97 1994-2003 7.3L Power Stroke 1 01-26-2008 04:47 AM
gauge question outlawcrewcab 1994-2003 7.3L Power Stroke 9 04-29-2007 07:22 PM
gauge question 99stroke 1994-2003 7.3L Power Stroke 2 02-12-2007 01:43 PM
EGT gauge question Robts 2003-2007 6.0L Power Stroke 3 02-20-2006 01:48 AM
