Wiring issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01CUMMINS24, this thread has received 2 replies and been viewed 732 times.
post #1 of 3 (permalink) Old 12-22-2009, 03:23 AM Thread Starter
01CUMMINS24
Wiring issue
My overhead console was saying ccd so I removed the battery cables and cleaned them up. I also cleaned a group of ground wires behind the driver side kick panel. Then proceeded to do my cab light install. Removed everything including the over head console. While it was down I plugged it back in to see if it still said ccd. It works now but won't stay on after key is turned on but will come on when u push step. Decided to check the dome light and it wasn't working. Put everything back together, checked all connectiions. Now I have no radio, dome light, or cargo lights. Checked fuses everything was fine. Checked schematic and didn't find anything. I applied power to the pink wire on the engine compartment light and everything came on. Truck starts and runs fine. Instrument panel works, all gauges. I don't know what else to check. I have looked all over for loose connections. Maybe someone can point me in the right direction?
01CUMMINS24 is offline
post #2 of 3 (permalink) Old 12-22-2009, 09:48 PM Thread Starter
01CUMMINS24
Fixed problem. Didn't see the fuse labeled I.O.D in the black holder. I wastold to check that. Removed fuse and sure enough it was blown. Installed new one and everything is back to normal.
post #3 of 3 (permalink) Old 12-23-2009, 03:02 AM
bmoeller's Avatar
Good deal. I would've suggested checking that IOD fuse myself.
"Obama = Hoax and Chains"
bmoeller is offline
Wiring Sabbath5.9 Supporting Vendors Forum 1 08-15-2009 09:43 PM
Wiring? Binderpower The Parking Lot 10 08-04-2009 01:43 AM
Wiring remote start/alarm, anyone have wiring diagrams? kjdavis 1994-2003 7.3L Power Stroke 3 06-22-2007 11:13 PM
Icp Wiring CABINETMAKER 2003-2007 6.0L Power Stroke 0 10-27-2006 01:14 PM
tune issue or tranny issue? licketysplit 2003-2007 6.0L Power Stroke 10 02-14-2006 10:58 AM
