Truck acting weird - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 8 replies and been viewed 1382 times.
post #1 of 9 (permalink) Old 12-24-2009, 05:19 PM Thread Starter
Its Cute Aint it!!
Truck acting weird
Ok when im driving the gauges on truck go to 0 and check engine light comes on. I let it do a dump and wait a lil hile and go to take off and trck will cut out and lights come on and it says no bus in the odometer. Comp box is off the truck. I dont know what the deal is. When all this started my battery gauge would peg out while going down the road. I would kill it and then start right ack up and it was fine.
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 9 (permalink) Old 12-24-2009, 08:55 PM
TDG Mafia
Jeffybuilt's Avatar
How are the connections at your batteries? Not saying this is the problem, but I had some real odd things happen with my electrical system for a while, until I put new terminal connections on and cleaned up my batteries real well.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 9 (permalink) Old 12-24-2009, 08:58 PM
Official TDG Doctor
hccumminssmoke's Avatar
check the batt connections and have your alternator checked...im thinking it may be bad bushings in your alt.
Nate
hccumminssmoke is offline
post #4 of 9 (permalink) Old 12-27-2009, 04:00 PM
I would also check the cable that runs to the power distibution area, conections and also check voltage from the batt to the other end by the power distibution area, the cable could be corroded inside and you would never see it.
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #5 of 9 (permalink) Old 12-28-2009, 07:52 AM Thread Starter
Its Cute Aint it!!
Thanks guys since it has started doin this i thought it was comp box. I took it off and truck hasnt done it. I put it back on the other day and By time afternoon rolled around truck was acting crazy agian. But i was also have battery terminal problems too. My positive terminal on drivers side isnt the best and i have cleaned it real good and done what i could to get it tighter and and so far so good. But i also havent put comp back on it yet. Do yall think its the comp or connections? This thing is a dog and needs something.
kc04 is offline
post #6 of 9 (permalink) Old 12-28-2009, 04:22 PM
TDG Mafia
Jeffybuilt's Avatar
That would be my guess, as mine has been acting weird with the Edge on as well. I am sending it in soon to be "checked out." Hopefully they can fix it.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #7 of 9 (permalink) Old 12-30-2009, 03:46 AM Thread Starter
Its Cute Aint it!!
Well i hate to speak too soon but 2 days with comp and so far so good. We will see. But i would think if it was comp it would act up regardless but we will see truck does have a mind of its own!
kc04 is offline
post #8 of 9 (permalink) Old 01-04-2010, 10:46 PM
Mine started doing that a while back, randomly. You'd cycle the key a couple times, or wait a few minutes, then everything was normal again. Did it on and off for 2 months - then the alt. died. Replaced the alternator, and it hasn't done it since. MAYBE coincidence, maybe not..........
Copper is offline
post #9 of 9 (permalink) Old 01-06-2010, 04:13 PM Thread Starter
Its Cute Aint it!!
Well still so far so good. Truck is acting fine with comp. I just think it was having a fit like most women!
kc04 is offline
engine acting weird..... biz 1994-2003 7.3L Power Stroke 8 12-09-2009 07:04 PM
Tranny acting weird skter97 2008-2010 6.4L Power Stroke 9 10-24-2009 09:52 PM
Acting weird! dmaxstreetking Duramax 07.5-2010 (LMM) 1 04-17-2008 06:57 PM
Truck acting up? bigtrxs 2003-2007 6.0L Power Stroke 1 03-31-2008 09:30 PM
Truck is acting funny RHCDIESEL 2003-2007 6.0L Power Stroke 6 10-29-2007 10:39 PM
