Lost power steering and brakes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigdaddy1, this thread has received 3 replies and been viewed 1116 times.
post #1 of 4 (permalink) Old 12-27-2009, 04:38 PM Thread Starter
Exclamation Lost power steering and brakes
I lost my power steering and brakes. I left it set for a couple days started it up and let it run for about a half hour and got them back, but had a loud noise coming from the pump when I turned our hit the brakes. I had read in a couple places to change the fluid, started to do this and noticed the fluid was all foamy. I changed the fluid and it took for ever to get power steering and brakes. Drove it this morning and lost it again, went to check fluid and seen it was coming out the fill cap, opened it up and it was all foamy again. What do I need to do?
bigdaddy1 is offline
post #2 of 4 (permalink) Old 12-27-2009, 05:06 PM
lcfa 45
When you bled your system did you get much air? was the system low or leaking before the foaming started? If bleeding is not done throughly enough air can be a problem until you can get it all out = Cheap fix. Otherwise it may be your pump = More$$
Lcfa45 is offline
post #3 of 4 (permalink) Old 12-27-2009, 06:18 PM Thread Starter
The book says to bleed the system you turn the wheel both directions till it stops. Is there another way to bleed it? It was foaming before this but not as bad. It done it one time last year but come out of it and been fine every since.
post #4 of 4 (permalink) Old 12-28-2009, 06:15 PM
TDG Mafia
Jeffybuilt's Avatar
When you bleed it, either have the front wheels off the ground, or on something that offers little resistance, like gravel. Also have the cap to the power steering pump off. Not sure if you have done it like that, but just a reminder. Hope this helps.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
No brakes or power steering?? gr33ng0bl1n 2003-2007 6.0L Power Stroke 3 12-02-2009 09:00 PM
Lost Power Steering and Brakes Red Power 6.5L Diesel Engine 3 02-20-2008 12:24 AM
no power steering/brakes help? Dodge-Power 5.9L Cummins 12 Valve (1994-1998.5) 8 12-09-2007 07:56 PM
power steering/brakes 2000cummins 5.9L Cummins (1998.5-2002) 1 08-14-2007 10:50 PM
