Steering box and front end - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MILKINGCOWBOY, this thread has received 6 replies and been viewed 1563 times.
post #1 of 7 (permalink) Old 12-27-2009, 05:10 PM Thread Starter
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
I have to replace my steering gear box soon. anyone have any advice on where to get them? is the napa one good or are there better ones out there with out spending $500? Also what s the difference or advantage to the different amount of turns i see one is 3 and 1/16 turns and the other is 4 and 3/16 turns?. Also I want to go threw the front end same deal and advice on upgraded parts or after maket or go with napas top line? thanks
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #2 of 7 (permalink) Old 12-29-2009, 02:36 PM Thread Starter
milkin cowboy
KEEP ON KEEPIN ON
post #3 of 7 (permalink) Old 12-29-2009, 03:27 PM
BUCK2's Avatar
I bought the front end rebuild kit from PST. There ball joints are not the best ( used some one elses). But the kit was very easy to install and included all the parts (Tie rod ends, New Polygraphite bushings for the control arms, and ploygraphite bushings for the sway bars, etc...). I think the kit is roughly 300+.
As far as the sterring box see if you get some one to rebuild it.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #4 of 7 (permalink) Old 12-29-2009, 07:57 PM
TDG Mafia
Jeffybuilt's Avatar
I got my steering box from Napa and it was $211. Just be sure to get the proper one...The first one they gave me...I put it on the truck, and when you turned the wheel left, the tires went right, and so on......SO....Don't make my mistake. As for front end parts, I have went with AC Delco, which have lifetime warranty. There are several good components companies out there, but you will have to decide if you want to go with something more specialized. Good luck...and the steering boxes are heavy.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #5 of 7 (permalink) Old 12-30-2009, 10:53 PM
bmoeller's Avatar
Moog parts seem decent.
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 7 (permalink) Old 01-03-2010, 04:16 PM Thread Starter
milkin cowboy
thanks guys,any one else have opinions on steering boxs or the aftermarket stabilizers and such?
KEEP ON KEEPIN ON
post #7 of 7 (permalink) Old 01-03-2010, 09:03 PM
bmoeller's Avatar
The SSI steering stabilizer and the 3rd gen track bar conversion made a WORLD of difference! Wished I hadn't waited so long to do it.
bmoeller is offline
front drive lineline will spin but wont lock into front axle Wally1tm 5.9L Cummins 12 Valve (1994-1998.5) 3 12-13-2009 07:33 PM
changing front main and front cover gasket, need advice SSpeeDEMONSS 5.9L Cummins 12 Valve (1994-1998.5) 30 07-17-2009 03:21 AM
steering Tornsteel General Ford Truck and Excursion 1 10-12-2006 03:08 PM
Steering & Steering Pumps sredish 2003-2007 6.0L Power Stroke 7 10-10-2006 01:48 AM
2002 F250 steering / front end play nichols General Ford Truck and Excursion 2 09-21-2006 02:44 PM
