Adjusted Valves - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jeffybuilt, this thread has received 4 replies and been viewed 910 times.
post #1 of 5 (permalink) Old 12-28-2009, 06:11 PM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
Adjusted Valves
I adjusted my valves the other day. It went pretty smooth, and other than 5 and 6 being kind of a pain to get to, it wasn't too bad! Truck sounds a bit quieter and feels to have a bit more response to it. All in all a good use of time.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #2 of 5 (permalink) Old 12-29-2009, 12:15 AM
Yeah, I've done mine a few times, for various reasons. And found that they weren't bad to do at all.
post #3 of 5 (permalink) Old 12-29-2009, 03:21 AM Thread Starter
TDG Mafia
Jeffybuilt's Avatar
Hey Sean, I'm planning to do injectors sometime in the near future. While I was in there, I saw where they were, and the hold downs and stuff, but will I need to take one of the rocker arms off of each cylinder to get to the injector, or will I be able to simply pull it with the rockers still in place?
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
post #4 of 5 (permalink) Old 12-29-2009, 06:11 AM
you can pull them without messing with the rockers.
01quadcab is offline
The Following User Says Thank You to 01quadcab For this addition to TDG:
Jeffybuilt (12-29-2009)
post #5 of 5 (permalink) Old 12-29-2009, 04:37 PM
Yeah, just make sure to loosen the lines and pop the crossover tubes back a little ways to get them free of the injector bodies, or else you can damage the tip of them.
The Following User Says Thank You to sstockton For this addition to TDG:
how to set valves kennyhammond 5.9L Cummins (1998.5-2002) 3 11-10-2009 01:01 PM
94-98 12 valves Cummins5390 5.9L Cummins 12 Valve (1994-1998.5) 8 12-10-2007 07:25 PM
No more delivery valves mrector 5.9L Cummins 12 Valve (1994-1998.5) 11 09-18-2007 08:59 PM
Pop off valves?? tahoedmax Duramax 2001-2004 (LB7) 14 02-21-2007 04:28 AM
New to 24 valves! CanadianCarGuy 5.9L Cummins (1998.5-2002) 10 02-07-2006 01:33 AM
