fuel gauge sending unit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by STROKER SMOKER, this thread has received 7 replies and been viewed 10365 times.
post #1 of 8 (permalink) Old 12-31-2009, 01:40 AM Thread Starter
STROKER SMOKER's Avatar
hey guys quick question. my damn fuel gauge hasnt worked in a while and i am lookin to replace the sending unit in the tank. has anybody on here done this before? I cant seem to find one on ebay so where are some good sites to get one for a good price? And can anybody give me a ball park of how much they cost for a 2001 cummins? thanks guys.
STROKER SMOKER is offline
post #2 of 8 (permalink) Old 12-31-2009, 05:22 AM
go with a factory unit it will last longer. My friend is on his 3rd from napa
01quadcab is offline
post #3 of 8 (permalink) Old 12-31-2009, 03:13 PM
sean3393's Avatar
before you buy a new one i'd make sure it's the fuel sensor module first. gauge quit working on my brothers 2000 and the float had broke off the arm. used some pool putty epoxy (leftover from fixing hot tub leak) to attach it back to arm and fuel gauge was back in business. wasn't sure how the epoxy would hold up to diesel, but so far 8 months and counting. good luck!
2006 Dodge Ram 4x4 Quad Cab 3/4 ton Laramie- Mostly Stock, 20" Eagle Alloys and cat M.I.A.
2003 Ford F250 4x4 4-Door- Head studs, EGR delete, SCT w/ ID tunes.
SOLD 1996 Dodge Ram 2500 4x4 Ext. Cab LB- 2.5" level lift, BHAF, 3k gsk, #100 plate, afc tuned, red oak injectors, 4in straight pipe, goerend tranny, timing, airdog 150, stock turbo for now
sean3393 is offline
post #4 of 8 (permalink) Old 01-01-2010, 12:43 AM
bmoeller's Avatar
Thought I saw they cost ~$400 from a dealer? Wasn't cheap anyhow.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 8 (permalink) Old 01-09-2010, 11:30 PM
having a problem with my gas gage
i have a 02 dodge 2500 sport.. i went to start my truck and the gas gage did what it usually does but didn't go to full tank it just stayed on empty.. i don't know what wrong.. Is there a sensor i can check for it? please help..
rlk200469 is offline
post #6 of 8 (permalink) Old 01-17-2010, 01:33 AM
acesneights1's Avatar
I posted 411$ from the dealer but that was for the whole fuel basket including sending unit. POS Lee's Auto Ranch in ellington CT put 100psi of shop air through mine and annilihated it. I got a used one from the Junky(what are the chance I found one) for 125$. it's pretty easy. Hardest part is getting those stupid quick release(quick my ***)connecotrs off the fuel tank. rest is easy.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #7 of 8 (permalink) Old 01-17-2010, 01:35 AM
you usually just need the float and you can get that setup from the dealer for 60-75 in that range for one. My 99 had that problem and it's fixed now. my float actually rotted off the arm.
post #8 of 8 (permalink) Old 01-17-2010, 05:17 AM
Check your local salvage yard. I was looking for a used tank and picked up the whole unit for 25 dollars.
later is offline
fuel gauge sending unit vcassens 2003-2007 6.0L Power Stroke 4 05-10-2009 07:55 AM
fuel pressure sending unit bootcamp 2003-2007 6.0L Power Stroke 17 04-06-2008 02:46 PM
fuel pressure gauge sending unit. Bcarriveau 2003-2007 6.0L Power Stroke 20 01-09-2008 04:05 PM
Fuel sending unit help Strokerin General Gas Vehicle 3 03-29-2007 03:18 AM
fuel tank sending unit just visiting Whats Been Sold 4 09-19-2006 07:01 AM
