P1693 and P0237 on 2000 Cummins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 3 replies and been viewed 5967 times.
post #1 of 4 (permalink) Old 01-08-2010, 11:47 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Well the title says it! Got a 00' Cummins with 5speed. Im thinking the P0237 is the MAP sensor voltage is too low and im not sure on the other one. All help is appricated! Thanks guys!
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 4 (permalink) Old 01-11-2010, 11:25 AM
What are sparkplugs
ICEMAN3005's Avatar
1693 is a generic code to tell that a problem has been detected and recorded, then your problem code flashes, in your case 0237.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #3 of 4 (permalink) Old 01-11-2010, 01:26 PM
Official TDG Doctor
hccumminssmoke's Avatar
yea 1693 is companion and 0237 is Map Voltage, clear them see if it pops up again, did you do anything to the truck? box wise, or has it had a smoke switch installed?
Nate
hccumminssmoke is offline
post #4 of 4 (permalink) Old 01-11-2010, 04:54 PM Thread Starter
Thanks guys, When the guy first got the truck it had a chip from edge (you could move the wires and set them on how you wanted the fuel and power) shortly after that he had to get a lift pump and when he got the new lift pump, he took off the chip from edge and added a power puke chip.Then after a few months the injection pump went bad, so he got a stock replacement pump and added a edge ez (i think) thats about the time the codes popped up but hes looking for torque to haul the camper to the beach and back.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
Code P0237 Again yfz450_0569 5.9L Cummins (2003-2007.5) 2 08-27-2009 03:57 PM
KTA Cummins, 600hp, $2000 nevrenufhp Whats Been Sold 3 06-30-2009 12:19 AM
2000 Ram 2500 CUMMINS 03 Power Smoke Whats Been Sold 5 06-10-2009 06:58 PM
trouble code P0237 bubba1541 1994-2003 7.3L Power Stroke 2 10-28-2006 02:08 PM
For Sale: 2000 4x4 Cummins DPS Whats Been Sold 0 02-16-2006 09:15 PM
