chip or tuner for 1999 5 spd manual - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bpul2113, this thread has received 10 replies and been viewed 1251 times.
post #1 of 11 (permalink) Old 01-10-2010, 12:02 AM Thread Starter
anyone have a recommendation for what chip or tuner to put on my 99 5spd manual its fairly stock, only has a bhaf 3 inch exhuast should i straight pipe the exhaust to stay with 3 in or go to a 4 inch exhaust
bpul2113 is offline
post #2 of 11 (permalink) Old 01-10-2010, 02:19 AM
bmoeller's Avatar
Depending on how crazy you want to get, and if you get a bigger turbo(s), the 3" will be fine, for a while.
Edge Juice or Smarty programmer should be good. The Juice has been great on my truck so far. Still haven't tapped the pump wire for the Edge, but it still gives a nice punch with a hand shaker.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 11 (permalink) Old 01-10-2010, 10:51 PM
Im not familair wit the smartys a lot of poeple like them, Lots of poeple like the edge I ve got the juice w/attitude its sweet.
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #4 of 11 (permalink) Old 01-11-2010, 01:37 AM
Its Cute Aint it!!
If you dont want nothin special edge ez. Edge comp or juice both are great if you dont do the wire tap its the same as ez. I think for what it is the juice or comp without wire tap is great. If you want to do wire tap i would definately get lift pump!
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #5 of 11 (permalink) Old 01-11-2010, 04:15 AM
if you don't have gauges then get the edge juice with attitude it has all you need and the ever important fuel pressure gauge. If you have them go with an edge comp. I have a 99 5 spd and the juice with attitude and really like it.
01quadcab is offline
post #6 of 11 (permalink) Old 01-13-2010, 02:21 AM
cowboytw13's Avatar
Your probably going to need a better clutch as well if you do the wire tap. Unless you drive with a really light foot. I think that my stock clutch would handle level 3 if I wasn't too hard on it.
cowboytw13 is offline
post #7 of 11 (permalink) Old 01-13-2010, 04:58 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
also you can get a steath plate for it, I think it usually cost is bout 60 dollars
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #8 of 11 (permalink) Old 01-13-2010, 05:54 PM
Official TDG Doctor
hccumminssmoke's Avatar
Mopar Man's clutch lasted a while on level 5 with his Comp
Nate
hccumminssmoke is offline
post #9 of 11 (permalink) Old 01-13-2010, 10:19 PM
cowboytw13's Avatar
Nate
Yeah, I'm still trying to figure out how he accomplished that. I guess it's all about how you drive.
post #10 of 11 (permalink) Old 01-15-2010, 03:30 AM
My clutch is stock run mine there a lot, but don't drive like a wild man till she gets rolling even have level 6.
1999 Ford Super Duty EVTM Manual POWER STROKE 99 1994-2003 7.3L Power Stroke 0 05-11-2009 12:47 PM
Ford EVTM manual for 1999 Super Duty POWER STROKE 99 1994-2003 7.3L Chips & Tuners Forum 0 05-08-2009 01:52 PM
tuner or chip stroker_baldy Supporting Vendors Forum 3 08-17-2007 03:53 AM
1999 dodge tuner????????? BUCKSHOT Dodge Performance Forum 11 12-12-2005 02:00 AM
Is a DP tuner the best chip bigwheeling General Ford Truck and Excursion 10 12-07-2005 02:55 PM
