What to look for? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PaleRider, this thread has received 1 replies and been viewed 655 times.
post #1 of 2 (permalink) Old 01-10-2010, 06:16 PM Thread Starter
Gettin By
PaleRider's Avatar
What to look for?
Looking for a 2000 - 2002 Dodge 2500 4x4. What milage should I expect and what do I need to be aware of looking at these trucks?
Thanks in advance!
PaleRider
___________
2008 Job #3 F-350 XLT, CC, SB, SRW 4x4. 2" Leveling Kit, AIR LIFT Bags & PuLLRite 18K Hitch & SCT Tuned
R.I.P. 2001 F-250 7.3 Stolen & Burnt To The Ground!
UNION CLUB # 13
PaleRider is offline
post #2 of 2 (permalink) Old 01-11-2010, 01:14 AM
bmoeller's Avatar
Lift pump failure is common. Takes out the fuel injection pump when that happens more often not. LP was dead on my '99 when I bought it last Feb, but so far the VP44 hasn't croaked, yet.
Check for worn trackbar/ball joints/tie-rods ends/steering stabilizer(s) - (like you should check on any truck anyhow)
Don't know if a 2000 would have a 53 block or not.
If you get a manual trans, it will either be a NVG4500 5 spd or the NVG5600 6spd. The 5th gear nut on a 4500 is a known problem. Likes to back off. Mine hasn't done it since I've owned it. Don't know if the PO did or not. Use OEM synthetic fluid in both.
OEM automatics don't like much power over stock.
Mileage is all over the map from what I've read. 14-21mpg range.
"Obama = Hoax and Chains"
bmoeller is offline
PaleRider (01-16-2010)
