53 block - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kc04, this thread has received 7 replies and been viewed 1119 times.
post #1 of 8 (permalink) Old 01-15-2010, 06:09 AM Thread Starter
Its Cute Aint it!!
53 block
Ok guys well guess what! Ive got one and its starting to crack. Ive got lil tracks from antifreeze below it right by the freeze plug. What should i do? Seems like everything i touch is falling apart
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #2 of 8 (permalink) Old 01-15-2010, 02:40 PM
pick up another short block and put your head etc on it.
01quadcab is offline
post #3 of 8 (permalink) Old 01-15-2010, 03:45 PM
WHOS NEXT
A new block costs about $2000 from cummins.
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #4 of 8 (permalink) Old 01-15-2010, 05:39 PM Thread Starter
Its Cute Aint it!!
Sorry guys wrong truck. My 12v is the one that has 53 block. 24v has 55 block. I meant to put in 12v forum. Thanks guys but it does suck cause just got truck put back together and got some of the bugs out. Looks like i get to break it down again.
kc04 is offline
post #5 of 8 (permalink) Old 01-16-2010, 02:58 AM
acesneights1's Avatar
I was not aware the 53 block was also found in 12v.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #6 of 8 (permalink) Old 01-16-2010, 05:07 PM Thread Starter
Its Cute Aint it!!
They started some time in 98 with 53 block. Build date is 4/98
kc04 is offline
post #7 of 8 (permalink) Old 01-17-2010, 01:30 AM
Gotcha, it's in the stickys too. I reread the 53 block one.
post #8 of 8 (permalink) Old 01-17-2010, 05:12 AM
Are you looking for a block? If so drop me a PM.
later is offline
The Following User Says Thank You to later For this addition to TDG:
kc04 (01-18-2010)
swapping 53 block with a 55 block DHenson 5.9L Cummins (1998.5-2002) 16 03-26-2008 12:59 PM
#53 block dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 3 11-11-2007 07:27 AM
53 block bad_cummins 5.9L Cummins (1998.5-2002) 5 09-14-2006 11:58 AM
egr block off ipkyss 2003-2007 6.0L Power Stroke 1 08-29-2006 11:27 AM
