24-Valve Current Draw on Start-up Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BombDocDiesel, this thread has received 5 replies and been viewed 898 times.
post #1 of 6 (permalink) Old 01-20-2010, 01:33 AM Thread Starter
TDG Mafia Goon
BombDocDiesel's Avatar
I am putting dual battery boxes behind the axle on Chum. I'm trying to determine how much current is drawn during start-up. I want to make sure I have large enough cables to safely carry the current. I don't have a pick-up for my Fluke to measure amperage right now.
Any information would be helpful. Draw in cold weather when grid heater kicks on and draw in normal conditions would be perfect.
Thanks!
If I put this in the wrong place, please let me know.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #2 of 6 (permalink) Old 01-20-2010, 02:28 AM
On Geno's Garage web site it says 450 to 700 amps.
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
BombDocDiesel (01-20-2010)
post #3 of 6 (permalink) Old 01-20-2010, 02:50 AM
1/0 welding cable will stand that many amps for 20 to 30 seconds. Longer than that you will need 500 mcm.
later is offline
The Following User Says Thank You to later For this addition to TDG:
post #4 of 6 (permalink) Old 01-20-2010, 03:54 AM
I would use 2/0 battery cable and solder the conections. "0" resistance and "O" problems, use old heater hose to protect it. Just a thought.
Johnp3 is offline
post #5 of 6 (permalink) Old 01-20-2010, 05:23 PM Thread Starter
TDG Mafia Goon
Thanks guys. I have access to a lot of 1/0 Industrial. I've used it before and it bends to form around things well. This 1/0 rated 245A and 2/0 at 283A for chassis wiring. I've been running this thing with one battery for over a year and a half. Maybe I'll finally put my horns on now as well.
I need a good source for used heater hose now. Loom is cheaper than new hose. How about 3/4" garden hose, the good stuff?
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #6 of 6 (permalink) Old 01-20-2010, 05:36 PM
Well I save old hose and slide it over the cable before I put the ends on after fitting it and figuring exactly where I want to run it and tie it, I like heater hose especially because if it is in a high heat area it will get a layer of carbon on it that works like a supper insulation. where as the loom will melt out of the way, exposing the cable If you have to buy it you only need it in the high heat areas, and loom the rest. Just a thought!
Johnp3 is offline
Draw Straw 1 rwhite 5.9L Cummins (1998.5-2002) 5 04-29-2009 04:10 PM
(94-98)12 Valve Newbies start here nevrenufhp 5.9L Cummins 12 Valve (1994-1998.5) 26 05-04-2008 03:11 PM
1997 12 valve wont start hotrod792000 5.9L Cummins 12 Valve (1994-1998.5) 31 01-07-2008 06:35 PM
12 valve hard start hotrod792000 5.9L Cummins 12 Valve (1994-1998.5) 10 08-10-2007 02:19 AM
