2001 RAM2500 again more ?'s . . . - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by M123KT-450, this thread has received 17 replies and been viewed 1689 times.
post #1 of 18 (permalink) Old 01-22-2010, 08:35 AM Thread Starter
M123KT-450's Avatar
Rebuild the Electronic 24V IP ?
or
P-pump it ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
1971 AMC /Jeep J4K-DRW.
1988 AMC /Jeep Comanche.
1991 Dodge RamCharger.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
M123KT-450 is offline
post #2 of 18 (permalink) Old 01-22-2010, 12:19 PM
Official TDG Doctor
hccumminssmoke's Avatar
overall a p-pump is nice to have, but the work and effort to get it, and get it tuned for just a average everyday go getter is in my opinion not worth it, its by far not a simple easy task, and it takes some time...
now if you want to have a ba puller or drag truck then yes throw a p pump on there...otherwise put a SO pump back on and be happy with the 600hp its capable of
Nate
hccumminssmoke is offline
post #3 of 18 (permalink) Old 01-22-2010, 12:41 PM
ADMIN/MAFIA
neeltburn's Avatar
I was under the impression that due to the electronics of the VP44 the end user ie owner could not rebuild a VP44? Mike I would call the injection /diesel shops in your area and see if they have the ability to rebuild it. Though a p-pump 24 valve would be sweet! What is the plan with this truck?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 18 (permalink) Old 01-22-2010, 02:23 PM
bmoeller's Avatar
If you had a spare 12v to use for the needed parts laying around, I'd probably P-pump it. But, if you don't, I'd just put a remaned SO VP back on. It is a pretty $$$$$ swap.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 18 (permalink) Old 01-22-2010, 02:24 PM
If you can get it to milwaukee, go to Huckstorf Diesel. There website is hdiesel.com. They charge 1650 to replace pump and install it. They by far have the best warranty around and really stand behind there work! I have been going there for 7 years and not once been disappionted! It is worth the trip. Almost anything they do is 1/2 the price of a dealer. If you put it in yourself, the rebuilt pump will cost between 1100 and 1300, with no warranty on your labor. With all the hassle, the 300 they charge to remove/install is well worth it. Also, makesure you get rid of the OEM lift pump and get a FASS or airdog. It then should be the last pump you do on the life of the truck, if you don't juice it up to much. In that case you would want a bigger pump anyways!
hin0031 is offline
post #6 of 18 (permalink) Old 01-23-2010, 05:29 AM Thread Starter
M123KT-450's Avatar
Its a tow Rig / Driver at the moment but this truck is going to be retired lifted built for Mud . . .
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #7 of 18 (permalink) Old 01-23-2010, 02:51 PM
p7100's Avatar
Send a message via AIM to p7100
none
If the truck is going to be built for the mud, then maybe it would be better to have a p-pump just because of the lack of electronics to keep out of the mud. But if you arent lookin for monster hp, the switch isant very cost effective.
1996 CTD ex cab LB, 5 speed 4x4, LUK clutch, 370"s, fully built and bench flowed pump from TRE Diesel, timing at 17*, airdog 150, aem brute force intake pullin air through a schwitzer 65mm charger, and pushin it out a FBD 5 inch exhaust painted flat black, 6 in. MBRP tip
Waitin for install, ARP studs, 4 GSK, and added timing
p7100 is offline
The Following User Says Thank You to p7100 For this addition to TDG:
M123KT-450 (01-24-2010)
post #8 of 18 (permalink) Old 01-24-2010, 12:45 AM Thread Starter
M123KT-450's Avatar
Alrighty i guess i'll keep that in mind . . . anything else ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
post #9 of 18 (permalink) Old 01-24-2010, 02:23 AM
just build a 12v for it and put it in there and sell off the vp stuff
01quadcab is offline
post #10 of 18 (permalink) Old 01-24-2010, 04:17 AM Thread Starter
M123KT-450's Avatar
How will P-pumping effect the transmission ? and other electronics ?
Mike
1953 REO M48 w/w.
1962 GMC C45.
1969 AMC AMX -390.
AMO #9860
B.O.M.B Squad #43
Dually Club #98
2001 RAM2500 steering issues ! ?'s M123KT-450 5.9L Cummins (1998.5-2002) 41 04-08-2010 06:09 AM
01' RAM2500 fuel milage drop. . . M123KT-450 5.9L Cummins (1998.5-2002) 22 01-11-2010 10:45 PM
2001 Ram2500 Power/Performance Mods. M123KT-450 5.9L Cummins (1998.5-2002) 16 12-15-2009 03:57 AM
help on 2001 97STROKER_08 1994-2003 7.3L Power Stroke 3 01-24-2008 02:21 PM
99 to 2001 CTD wrongway Whats Been Sold 0 05-29-2006 03:35 AM
