Dead VP44 Test - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by p7100, this thread has received 11 replies and been viewed 2077 times.
post #1 of 12 (permalink) Old 01-24-2010, 06:43 AM Thread Starter
p7100's Avatar
Send a message via AIM to p7100
Dead VP44 Test
Hey,
Is there any test that can be preformed to see if a vp44 is on its way out? I know of doing the fuel pressure test already, I was just wondering if there is any other test that can be preformed....
1996 CTD ex cab LB, 5 speed 4x4, LUK clutch, 370"s, fully built and bench flowed pump from TRE Diesel, timing at 17*, airdog 150, aem brute force intake pullin air through a schwitzer 65mm charger, and pushin it out a FBD 5 inch exhaust painted flat black, 6 in. MBRP tip
Waitin for install, ARP studs, 4 GSK, and added timing
p7100 is offline
post #2 of 12 (permalink) Old 01-24-2010, 03:37 PM
Have you checked for codes? You can do this on some of the trucks by turning the key on and off 3 times stopping the third time and watch your speedo. If you have a code it will flash it back to you.
later is offline
post #3 of 12 (permalink) Old 01-24-2010, 03:47 PM Thread Starter
p7100's Avatar
none
Yes, I have checked for codes and there are a couple that have to do with the injection system, I cant remember exactly what they were offhand.... The tachometer bounces around at idle, and someone told me that this is a sign that the pump is going out... any truth to this?
p7100 is offline
post #4 of 12 (permalink) Old 01-24-2010, 05:42 PM
When mine died from a lift pump, it would just start up and not give any throttle response. Write down your codes you will need to know that. It could be something else.
later is offline
post #5 of 12 (permalink) Old 01-24-2010, 09:46 PM
Official TDG Doctor
hccumminssmoke's Avatar
Dead IP will not always throw codes...
Nate
hccumminssmoke is offline
post #6 of 12 (permalink) Old 01-24-2010, 10:22 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Mine does that. Far as i know its normal! What is your fuel pressure? usually i say if its between 10-13psi its the lift pump and if its below 10psi its your pump and most likely your lift pump too! So be sure to check the lift too.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #7 of 12 (permalink) Old 01-24-2010, 10:55 PM
Nate
What about 1693?
later is offline
post #8 of 12 (permalink) Old 01-25-2010, 01:39 AM
Official TDG Doctor
Originally Posted by later View Post
What about 1693?
Just a companion code, doesnt mean your IP is dead...
Nate
post #9 of 12 (permalink) Old 01-25-2010, 04:01 AM
I will need to disagree with you on that. 1693 means there is a error in both the ECM and PCM which you make me start checking the fuel system.
later is offline
post #10 of 12 (permalink) Old 01-25-2010, 12:08 PM
Official TDG Doctor
Im just saying 1693 does not mean that your IP is dead, yes it may be thrown and associated with your fuel system, 1693 is throw with a lot of stuff...Cam Sensor for one...
Nate
vp44 vcassens Supporting Vendors Forum 3 08-17-2009 02:17 PM
Another Dead VP44 acesneights1 5.9L Cummins (1998.5-2002) 13 08-02-2009 04:40 PM
Hot VP44 or Blue Chip's VP44 Mad Dog Cycles 24 Valve Performance 12 05-03-2009 01:38 AM
vp44 dodgeman00 Whats Been Sold 3 03-11-2009 01:41 PM
Vp44...... blackcloudCTD95 Dodge - Modification instructions, Product installs and Tech Articles 1 01-12-2009 06:36 PM
