programmers - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rdnckcummins02, this thread has received 8 replies and been viewed 960 times.
post #1 of 9 (permalink) Old 01-25-2010, 11:28 PM Thread Starter
programmers
I have a 2002 cummins 6 sdp, and i was curious what is the best programmer/chip for my truck
rdnckcummins02 is offline
post #2 of 9 (permalink) Old 01-25-2010, 11:35 PM
TDG Mafia Goon
BombDocDiesel's Avatar
First, welcome to the Garage!
This will be a good thread. There are a lot of different opinions out there. I run a Quad Adrenaline.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #3 of 9 (permalink) Old 01-25-2010, 11:48 PM
Smokin Okie
04cumminsram's Avatar
Honestly bud with a stick the chip ive had the best results with is the adrenaline... its a strong box and then you have the ability of being able to update/upgrade software online... and if you buy the pulse with it you take care of the gauges and for 100 bucks more you can get the fuel pressure sender with it and you would have all you need all in one chip
there are guys that run comp boxes from edge but they offer you none of the above other than a adjustable chip
04 hybrid...
it smokes a lil bit
625/1152...1-23-2010
www.smokinokiediesel.com
04cumminsram is offline
The Following User Says Thank You to 04cumminsram For this addition to TDG:
BombDocDiesel (01-26-2010)
post #4 of 9 (permalink) Old 01-26-2010, 12:03 AM
Official TDG Doctor
hccumminssmoke's Avatar
1st off gauges, no matter what...
if you dont have gauges the Edge Juice with Attitude or the Quad Adr. is a good choice b/c of the built in gauges...
personally i dont like the electronic display gauges, and I run Isspro's and an Edge Comp..
Another thing to be aware of is fuel pressure, the Lift pump on these trucks are very weak and usually only supply the IP with 13-15psi at idle and are not reccomneded below 10psi at idle and 8 at WOT and as you can guess an aggressive fueling box will kill it witch in return will starve of fuel (its only source of lubrication) and kill the IP which is quite costly...a common fix for this is a FASS system mounted on the rail or a Pure Flow Tech Pump (Air Dog/Raptor) on the rail...
Check your FP and then start looking at boxes...
Nate
hccumminssmoke is offline
The Following User Says Thank You to hccumminssmoke For this addition to TDG:
post #5 of 9 (permalink) Old 01-26-2010, 12:53 AM Thread Starter
i was planning on putting an airdog 150gph on my truck because that will take me through alot of modifications. What do you guys think about a smarty or a ts?
post #6 of 9 (permalink) Old 01-26-2010, 12:59 AM
Official TDG Doctor
Smarty is good i love mine...I didnt throw in TST completly forgot to...but the good thing about the others (and the tst) is you can change it on the fly, and the Smarty is a downloaded tune..
Nate
post #7 of 9 (permalink) Old 01-26-2010, 06:20 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
then also too you got to beware of the clutch, if you have lead foot, your clutch will be the first to go. i would rather invest in the clutch and the airdog first then think about programmers
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #8 of 9 (permalink) Old 01-27-2010, 02:05 PM
bmoeller's Avatar
Not 100% true. The Edge Juice w/ Attitude monitor gets you all the gauges as well. Happy with mine. The Drag and EZ boxes don't, though.
"Obama = Hoax and Chains"
bmoeller is offline
post #9 of 9 (permalink) Old 01-27-2010, 05:43 PM
Then also to you cant update the monitor to fit with the EZ boxes
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
? about programmers D-Man 5.9L Cummins (2003-2007.5) 9 01-12-2010 06:41 PM
programmers cwise09 5.9L Cummins (2003-2007.5) 10 02-13-2008 03:46 AM
programmers cwise09 2003-2007 6.0L Power Stroke 5 02-04-2008 07:03 PM
6.7L Programmers MegaInferno 6.7L Cummins (2007.5-2011) 10 11-07-2007 07:00 PM
SCT Programmers Q&A Choke_On_My_Smoke 2003-2007 6.0L Power Stroke 40 08-17-2005 04:37 AM
